Question about E-Machines eMachines Monitor E15T4
How can i remove the scenario mode from my screen?
My monitor screen
Want to get rid of scenario mode
Unfortunately, without a specific model number for your monitor, this may vary from the manual I am referencing. Just the same, I should say the link should at least have enough similarities to get you out of a scenario mode, and into the custom configurations (that I am assuming you are after).
The steps begin on the bottom of page 5.
http://global-download.gateway.com/GDFiles/Document/User%20Manual/User%20Manual_Acer_1.0_A_A.zip?acerid=634321354437313817&Step1=MONITOR&Step2=FLAT%20PANEL&Step3=E182HL&OS=ALL&LC=en&BC=EMACHINES&SC=PA_6E
If you are using a similar model, clicking on the menu button will bring you in the OSD menu where you can customize the brightness, contrast, etc. Any changes will become a "custom" mode that will effectively take you out of anyone of the scenario modes. I have seen monitors that do not allow much customization (if any) outside of the scenario modes. You may find specifics if you search the monitor model number itself. If you post that information in the comments I can help you find info more specific to your display.
Jan 03, 2016 | E-Machines Computers & Internet
My sansui pc/tv monitor isn't working properly when I connect it to my desktop.
Windows is likely crashing while loading recently upgraded device drivers. The most common culprits for this scenario are video drivers.
The next time you boot, as soon as you see the Dell splash screen, start tapping the F8-key about once every second until you see a white on black menu. If you see the Windows logo, you missed it (try again, this time start tapping the F8-key a little before the Dell splash screen).
This menu will allow you to boot Windows in "Safe Mode", which will bypass any non-essential drivers and applications that could be causing the crashing. Select "Safe Mode with networking".
Assuming the computer booted fine in Safe Mode, you will be able to remove the troublesome drivers. You will see an informational message about Safe Mode, which you may close at any time. Right-click "My Computer" and select "Manage". Wait a moment for the Computer Management window to appear. Then, click on "Device Manager". If Windows was able to identify the faulty driver, it will appear in the list with a bright-yellow triangle. If this is the case, right-click and "uninstall" it. If it did not show up, first click the tiny white triangle next to "Display Adapters" and "Monitors" to open those categories. Then, right-click and "uninstall" everything listed within the two categories. Your computer will probably boot normally after doing this. But, try and find the proper driver for you video adapter before rebooting if possible. I recommend also re-installing the chipset drivers which may be related to the problem.
To attain drivers for your specific Dimension B110, visit the following link and enter the service tag code on the back or side of your machine: Dell Drivers
Oct 28, 2012 | Sansui HDLCD1912 19in LCD HDTV 720p
Nonpreset mode
It just shows you that you are not at your best view mode.
Try increasing the screen resolution.You will get fixed.
Jun 09, 2012 | BenQ FP91G+ 19" LCD Monitor
Computer is in analog power saving mode, This comes on screen at start up and then screen goes black. I am on a laptop as my problem is on my desktop computer.
This is most likely due to the computer itself is not functioning in and this is the typical reaction of a monitor that is powered on and not receiving a signal from the computer. What is the state of the PC when you turn it on? Any lights, fans do you get picture at all on the monitor before the power saver mode kicks in? Most likely scenarios
  • Video card is bad on the computer
  • Power supply is bad on the computer
  • Motherboard is bad on the computer
P.S. Even if you have lights and fans working on the computer one of these three parts can still be bad. You can rule out the monitor by plugging it into your laptop and toggling the display (generally done by pressing the FN key and F7 or whichever F key has a screen icon on it)
Comment back for further troubleshooting. Thanks!
Aug 25, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Are screen savers good for TFT monitors
unless the monitors are being turned on and off frequently the sleep mode idea is alot more efficient
Mar 30, 2010 | Dell E197FP LCD Monitor
When screen comes out of screensaver/sleep mode,
It's a bad LCD screen or bad video card. If its a laptop, try to hook an external monitor to the video port in the back and see if it has the same problem. If it is the same problem, then you know its the video card and not the monitor screen. If you have a desktop PC that has this problem, its most likely the video card. First try removing the monitor and trying it on another computer to see if the monitor is bad. If not, then remove and replace your video card and restart. If same problem, replace video card with a new one.
Sep 16, 2009 | Computers & Internet
How do u remove the word Analog from the screen
enter the monitor menu and browse for options, such like "don't show monitor input mode"
Sep 11, 2009 | Computers & Internet
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
White screen
Hi.
Generally an all white screen scenario is caused by no signal from the monitors video board getting to the actual screen.
It could be as simple as a disconnected ribbon cable that mounts the two items.
It could also be a fuse on the back of the actual lcd screens circuit board. These fuses are usually labeled F1.
If you have a tester and the capabilities, in normal running mode the screen should be getting around 5 volts dc at this fuse.
The other problem could be a bad video board. These are not always repairable.
Bammbamm@ptd.net
Dec 13, 2008 | Computers & Internet
Chi Mei corporation 221D monitor problem no power
well i want to tell u that is a very common scenario u just replace the fuse and sometimes due to power low and high the fuse gets blown and u might also wanna check ur power chord.
Oct 24, 2008 | Chi Mei Corporation 221A Monitor
E-Machines eMachines Monitor E15T4 Logo
128 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
