Error 49 in HP LaserJet 100 color mfp m175a
HP printer error 49:
Error [b][i][u]49[/u][/i][/b] is [b]'Firmware Error'[/b].
[i]Firmware[/i] is the built-in software on the printer's electronics.
In layman's language, your printer's brain has become confused.
Here are several steps you can try, to hopefully clear the error:
[table]
[tr]
[th]01:[/th]
[th]Cancel Print Job[/th]
[th][b]Cancel[/b] via printer menu [i]and[/i] via Windows' Control Panel, to make sure.[/th]
[/tr]
[tr]
02:[/td]
Turn Printer Off[/td]
Power it [b]OFF[/b], then [b]ON[/b] again.[/td]
[/tr]
[tr]
03:[/td]
tESTING..[/td]
Try reprinting, to [b]test[/b] if [b]error[/b] has [b]gone[/b].[/td]
[/tr]
[tr]
04:[/td]
Try Different App[/td]
In case the [i]application[/i] is [b]corrupt[/b] or non-compatible, try printing from [i]other software program[/i].[/td]
[/tr]
[tr]
05:[/td]
Try Different File[/td]
In case the [i]file[/i] is [b]corrupt[/b] or non-compatible, go back to your [i]original application[/i] and try printing another file.[/td]
[/tr]
[tr]
06:[/td]
Upgrade Driver[/td]
If you find that [i]only certain files or apps cause problems[/i], [b]upgrade[/b] the printer driver to the latest version.[/td]
[/tr]
[tr]
07:[/td]
Upgrade Firmware[/td]
If the driver upgrade does not give you any joy, a [b]firmware upgrade[/b] may be necessary.[/td]
[/tr]
[tr]
08:[/td]
Refresh Entire System[/td]
Failing all of the above, an entire refresh / reboot may be necessary:[/td]
[/tr]
[tr]
09:[/td]
Freshen Up[/td]
Turn printer [b]OFF[/b]. Pull all printer-connected cables [b]OUT[/b]. In Win Control Panel / Devices, [b]DELETE[/b] Print-Queue. Switch [b]OFF[/b] computer. [b]REBOOT[/b] computer and printer. [b]RECONNECT[/b] cables. Try [b]PRINT[/b] again.[/td]
[/tr]
[tr]
10:[/td]
Clean Computer Registry[/td]
In addition to the 'Freshen Up' steps, a [b]registry cleaner[/b] application can clear software junk or old settings that may be causing a conflict. [b]360 Amigo Speedup[/b] does the job well.[/td]
[/tr]
[tr]
11:[/td]
Remove EIO Devices[/td]
Certain hard-drives, cards, etc are EIO * devices. Identify then [b]REMOVE[/b] all of these, and see if problem vanishes.[/td]
[/tr]
[tr]
12:[/td]
Re-install EIO Devices[/td]
Plug in the EIO devices again, one at a time, rebooting and testing printer each time [u]until one causes the error[/u].
[/tr]
[tr]
13:[/td]
Still failing, all EIO devices removed?[/td]
The memory cards (DIMMS), aka '[b]D[/b]ual-[b]I[/b]nline-[b]M[/b]emory-[b]M[/b]odules' of the printer itself may be damaged or corrupt.
[/tr]
[tr]
14:[/td]
Remove Printer DIMMS[/td]
Turn printer [b]OFF[/b]. Remove all DIMMS (memory and 3rd party if any) from the printer. DO NOT remove the FIRMWARE DIMM. Printer [i]will[/i] [u][b]CEASE[/b] to function[/u]![/td]
[/tr]
[tr]
15:[/td]
Try DIMMless analysis[/td]
Turn printer [b]ON[/b]. If error 49 remains, [b]RENEW[/b] the [b]FIRMWARE DIMM[/b]. If this doesn't work, [b]RENEW[/b] the [b]formatter module[/b]. May require [i]qualified personell[/i].[/td]
[/tr]
[tr]
16:[/td]
Test for faulty DIMM[/td]
Turn printer [b]OFF.[/b] Re-insert each DIMM, one-by-one, switching [b]ON[/b] then testing error each time, then [b]OFF[/b] for next one.[/td]
[/tr]
[tr]
17:[/td]
Faulty DIMM found - NOW what??[/td]
If one of the installed DIMMS re-creates the error, [b]RENEW[/b] the DIMM with a new one.[/td]
[/tr]
[tr]
18:[/td]
Hookup everthing again[/td]
Once all tests have been done, [b]restore[/b] all printer / computer [b]cables[/b] to the way they were before, for normal operation.[/td]
[/tr]
[tr]
[/td]
* EIO[/td]
No, NOT vowels of the alphabet. In this case it's an acronym for [b]E[/b]lectronic [b]I[/b]nput [b]O[/b]utput device[/td]
[/tr]
[/table]
In fact, the above steps can apply to [i]any[/i] printer, as well as many other computer peripherals.
Causes of the error can vary, including but not limited to:
electronic failure, power surges, strong EM fields, static, corruption, etc.
First, if you don't have one already, suggest you invest in a socket or multiplug outlet with a built-in '[b]Surge-Arrestor[/b]'.
A good, updated AV is also a necessity to safeguard against cyber-attacks (see [i]corruption[/i] above).
