Good Afternoon Leslie,
I understand you are unable to start your Frigidaire dishwasher unless it is on a delayed cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Hello Theresa Norman-Ramirez - Typically, it is normal for the dishwasher to delay the cycle and depending on the cycle and options selected, the cycle may last up to 4 hours. To reduce cycle time, turn on the hot water at the sink and allow it to get as hot as possible (between 120 F-130 F), then start the dishwasher. If the dishwasher cycle runs longer than 4 hours the main control board may need replacing. I would suggest contacting an experienced service technician to determine the precise cause.
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
set delay to zero? or off?
