If it Sirius capable, get the radio's Sirius satellite ESN, (electronic serial number), from your radio and call Sirius satellite radio and they will tell you what to do. I don't know how to get this number from your unit but in my Lincoln, all I had to do was push and hold the Sirius button on the dash with the radio on and it popped up on the display. Your instruction manual should tell you how to do it. If it isn't compatible, you'll have to buy a Sirius receiver and have it activated with them. Good luck.
I am having the exact same problem with my CMD6. The sirius worked fine with my CMD4, but has the same problem with constantly rebooting when I hook it up to the CMD6. Did you find a solution?
The information as to what is playing is part of the data stream sent by Sirius, and I've never seen a satellite receiver that does not display this information. If this is a factory unit, information on its operation should be in your owners manual (and your dealer is there to help you). If this is an aftermarket radio, you ought to have an owners manual which should describe how to change the information displayed on the faceplate. Either way, the unit should give you full information about the data stream it is receiving. If not, something is amiss and may fall under warranty coverage.
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Look at the bottom of your unit, you'll notice the round port next to the slot? It get's jammed up inside the unit if you pressed to hard setting it into the cradle at some point. Not easy to fix, unfortunatley.
Hello, I had the same problem with my xact xtr1 and I was advised by xact that they have no repair process in works and most likely wont. They did say let it run for 10 minutes and once you have a menu switch to factory defaults which proves to be a worthless fix. I would have to pay $39.95 for a new radio...horrible customer service. The bright side is that Sirius will not charge me the $75.00 transfer fee as a good faith gesture. I have decided to switch to another radio and leave the Xact brand out of the equation, if there is no upgrade or modification to the existing equipment why set yourself up for a future failure.
How did the dealership resolve the battery draw issue. Did they rewire the Sirius for you. If so they could have wired the unit wrong. If you have a newer vehicle most of the wires in the dash are a very light gauge and most fuctions are controlled by, what's called a Body Control Module. Some of these wires are not a very good place to draw power from not onlt could it damage your Sirius Radio it could damage the electronics in your car as well. I suggest getting it looked at by a professional. Then go from there.
