This link will guide you step by step using pictures.
How to Change the Language in Android
Good luck, please post back if you are having trouble due to a difference in operating system.
SOURCE: Change text message language in Samsung SGH-U900
Try holding down the # key and a menu should pop up with the various typing styles. I changed mine to T9 abc and it works fine now
SOURCE: change the language english from italian
Go to Main Menu/settings/system/Regional Settings
Change the location here. If you have the problem still then try doing
the hard reset in the same location. Once the phone restarts, then
specify your region and language.
Do remember to backup your data before doing the hard reset. I hope it helps
SOURCE: dictionary language for text messages changed
i was having a similar problem, if you go into a message and then press down the bottom where you would change the keyboard/input type (Samsung Keyboard, Samsung Phonepad ect.) > select Options....... >Input method tab > options > select English from the drop box > check that the XT9 Settings is also set to English. I hope this fixes the problem for other people with the same issue
SOURCE: how to change language to english
Hi friend,
If there is English language in your cellular phone,you just need to set it,you can find..to get more information,you may visit our website:
www.1010store.com.
But if there is not English languge,you can only install the English language,but it will cost much money.
