Question about Olympus VN-8600PC Dictaphone
My PC wont detect my dictaphone
It's plugged in properly and the screeen says please wait but it isn't appearing in "My Computer" for access.
  • Olympus Master
  • 3,247 Answers
Please refer to page 15 on this user manual to ensure you follow the correct steps to connect the dictaphone to PC using USB port.
http://www.olympus.at/site/rmt/media/consumer/pim/_manuals_aw2010_/VN-8700_8600_8500_PC_MANUAL_EN..PDF
Posted on Jun 27, 2014
6ya staff
SOURCE:
Network adapter hp6505f
If your computer has a wireless network adapter, Windows will automatically detect wireless networks in range of your computer. You can see a list of wireless networks that Windows has detected in Connect to a Network.
  • Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
If Windows doesn't detect a network that you think is in range of your computer, it could be because of one of the following reasons:
  • The wireless switch on your computer is turned off.
    Many laptops have a wireless switch on the front or side of the computer. If your computer has a switch, make sure it's turned on. Some computers also use a function key combination to turn the switch on or off. Check the information that came with your computer for details on locating the wireless switch.
  • Your computer is too far from the wireless router or access point.
    Move your computer closer to the router or access point. If the computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer.
    If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than a built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna.
  • The wireless router or access point is turned off or isn't working properly.
    There are two things to try:
    • Make sure the router or access point is turned on and that the wireless signal light is illuminated.
    • Reset the router or access point by unplugging it, waiting at least 10 seconds, and then plugging it back in.
Sep 10, 2012 | NEC Computers & Internet
The dvd player wont open and it isn't reading dvd's.
You will want to check in Device Manager to see if the device is even detected by the computer. Right Click My Computer, Properties, Click Hardware Tab and Device Manager. If it isn't recognizing the DVD drive then it is most likely bad.
Nov 30, 2011 | HP Compaq Presario SR5010 Desktop PC...
How to fix this
update use online update software blackberry
Nov 23, 2011 | RIM BlackBerry Curve 8520 Smartphone
Laptop will not recognize psp
Hi lawolf77,
If your laptop wont recognize your PSP there might be a connection problem between the two. So you need to check what's causing the problem. There are several ways to check if PSP and your computer are properly connected, one good example is by checking the connectors and the device setting.
If you want to check some configuration on how to connect your PSP to your PC please try to follow these steps:
1. First, connect your PSP to your PC using a usb cable.
- please make sure both ends are properly intact.
2. Using the left and right directional button find "Setting", then scroll down or up to find the "USB CONNECTION".
3. USB CONNECTION will display after you pressed the x button.
4. Please wait until computer detects the USB connection. After that it will show the drive for your PSP. usually F: or G:
5. Click on your PSP drive letter.
6. Now you can determine if your PC recognizes the PSP, just access the root folder and try to put some files on it.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
My kodak easyshare M580 wont download onto my computer. where am i going wrong?
DEAR SIR,
The best way to download pictures from your camera to your computer can be done by two means....
1.INSTALL THE SOFTWARE C.D GIVEN ALONG WITH THE CAMERA IN YOUR NOTE BOOK....
THEN SWITCH ON YOUR CAMERA AND CONNECT THE CAMERA TO YOUR P.C VIA U.S.B CABLE,AND WAIT FOR FEW SECONDS FOR THE P.C TO DETECT YOUR CAMERA,ONCE THE CAMERA IS DETECTED IT WILL ASK YOU,WHETHER TO COPY YOUR CAMERA IMAGES TO YOUR P.C
2..Remove the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
thank you..take care
Oct 06, 2010 | Kodak Easyshare M580 Digital Camera
I installed a4tech pk-35n webcam but upon opening it through hamcap message is saying no video capture hardware. please help
It is because your computer can't detect the a4tech webcam, the proper way of installing is first don't plug in the a4tech device, install the driver first then plug-in the a4tech device, wait for the computer to detect your webcam. Make sure that the installation is complete. If the installation ask you to restart your computer, do it right away.
Jan 15, 2010 | Computers & Internet
My gemtek wl-299c wont work on my computer, it detects it but even if i manually put the IP address it wont connect, its supposed to be plug and play I dont need drivers but in case I do where can I...
It seems that your adapter is plug and play since it does not require drivers to work. Check the device status under the Device Manager and see if it was detected and properly installed.
How to got o Device Manager:
1. Right click on My Computer then select Properties
2. Select Hardware tab then click on Device Manager option
3. the adapter should appear under Network Adapters
If the drivers were properly installed PING the adapter to see if it is responding.
How to PING the adapter:
1. Go to command prompt by clicking on start then under accessories.
2. Type "ping loopback" on the space
If you get replies then the adapter is working!
Hope this helps. Please do not forget to give comments to this solution.
Thanks!
Jul 05, 2009 | Computers & Internet
Blue screeen with error on RT2500USB for wusb54gv4
Driver problem. Go into control panel and delete the adapter drivers. Remove the wifi adapter Then re-boot. I suspect the BSD (blue screen of death) was a result of a driver problem. If you have another computer that you can get on the internet with, go to the manufacturer website and download a driver. If you can get one, install the driver BEFORE plugging in the device and wait for the install program to prompt you to plug in the device. If you can't download a new driver, try plugging in the device again and see what happens. You need to avoid the BSD.
Sep 02, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Internet wont work
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
May 08, 2008 | D-Link AirPlus DI-524 Wireless Router
Dictaphone MicWiz
Catherine, did you ever get an answer for your problem with MicWiz? I am a transcriptionist that works from home and they are having problems getting it to recognize my foot pedal (as well as another MT) with the new software. It is recognized by Express Scribe and ever other system we use, but not Merge.
Thank you, Cindy
Apr 23, 2008 | Dictaphone 2740 Desktop Cassette...
Olympus VN-8600PC Dictaphone Logo
156 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
