There's a short somewhere in the oven. You need to find this. The timer issue was the result of the other issue.
sometimes the issue is easy to locate as there will be marks on the item indicating a problem. Sometimes it's a component that need to be replaced that's not so obvious and needs to be tested for the proper intake and output voltages.
SOURCE: Jennair 30" wall oven display is totally off.
Yes. I could use some help. What part exactly does one need to order. Have same issue with a W2750W.
Thank you!
SOURCE: JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
SOURCE: f-7 error code on jennaire oven
My control panel died completely and I purchsed a new on. when I plugged it up I am getting an F& error code. How do I clear that?
