SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
SOURCE: HAVE A FRONT LOAD WASHER ITS A FRIGIDAIRE ATF6000ES MY CLOTHES WILL STILL SOAKIN
first check you dains hose then the drain pump sound like it not draining out so it will not spin
SOURCE: FRONT LOAD WASHER
ther is something blocking the drain pump, check the water coming out from the drain if its floating out good if not there may be a sock or a bra wire inside the pump.
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
SOURCE: Frigidaire Gallery Series GLTF2940 front load
check the belt make sure it is still contected.
if that is good you may have a faulty door lock
