We are asking what number, times itself, is equal to 30. Five times itself is 25. Six times itself is 36. The answer is somewhere between 5 and 6. Let's split the difference and try 5.5. 5.5 times 5.5 is 30.25. This is above 30, so let's try a smaller number, 5.4. 5.4 times 5.4 is 29.16. This is lower than 30, so we need a higher number. How about 5.45? I get 29.7025. We need a number a little higher. How about 5.47? I get 29.9209. Still need a little higher. How about 5.48? 30.0304. So it is somewhere between 5.47 and 5.48.
On a calculator, you can use the square root function. Sometimes you have to enter the number before you hit the square root function and sometimes you need to enter the number after hitting the square root function. Another way of doing it is to use the exponent function, usually with a y to the x key or a ^ key. Enter 30, hit the exponent key, and then enter 1 divided by 2 in brackets.
I get approximately 5.477225575051661134569697828008.
are you sure that you have recharged the battery fully ?? It could be some kinds of virus, try to remove all connections and extra cards and try to open it again
No - the buzzing you're hearing is probably the inverter transformer. Its' purpose is to generate high voltage to turn on the backlight to display the image on the screen. The monitor should still be under manufacturers warranty since most of them are a year. Have it repaired or replaced.
try to boot in safe mode by pressing F8 when you turn on the computer
use the up/down arrow key to highlight safemode and press enter
press enter to select your OS then wait until it loads.
during boot up if it still shows the little squares try a known good monitor if it has the little square the video card is busted and needs to be replaced however if ever the known good monitor doesnt have the little square then its the monitor that needs to be replaced.
hope this help
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
