When I turn it on all I get is the start up screen saying initializing, but it never does,it will stay like this until I turn it off or the battery discharges!
SOURCE: RCA Lyra MC5102A
connect lyra to computer
go to my computer on your start menu
lyra will show up on other devices or portable devices
double click on the lyra icon
this will bring up another lyra icon right click on that
go down to the option format and select that
you will lose all of your music
solved my problem two hours after it started
SOURCE: my rca opal mp3 player freezes on the screen where it says initializing when i turn it on?
Go to "http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2559"
To update the firmware of the M42xx mp3 player click here
and download the firmware. start the firmware and when it is runnin
plug the M42xx in at the same time holding down the PLAY BUTTON
(center) until a white screen with a small computer with a line going
to your M42xx is displayed and then release the PLAY button. You can
then click on start and the firmware update will complete,,, DO NOT
DISCONNECT DURING THIS UPDATE... it may take 2 times to complete this
but it will work.... YEA!!!!
CARL
SOURCE: RCA Opal Initializing Problem
our firmware went bad.
Just got to the RCA website.
http://www.rcaaudiovideo.com/
search your make and model
Then hook you mp3 player to usb device of your computer.
After mp3 is hooked to computer
Install the newly downloaded firmware.
SOURCE: My RCA TH1611 mp3 player freezes upon booting.
Sometimes the firmware or player files are garbaged and the player
looks like it starts halfway then freezes. If this is your problem and
you're sure the battery's fine (and in the right way) then you can try
to reload the flash on the player and as a last resort reformat the
file area as well.
Go the RCA support website and download the latest flash for
the th1611 and run the program. You may be lucky off the bat, but if
the first attempt fails review the troubleshooting procedures that will
tell you to hold the play button while plugging the device into the usb
port. If, after the program flash, the device still fails to start,
you'll have to erase the file area to un freeze the device.
I
had a weak battery that that I pulled out while the device was starting
and it seemed to corrupt the player. Thisprocedure worked for me.
FYI, the flash program works on XP 32bit, but I don't know if it will work with Vista
SOURCE: Frozen screen RCA M4208RD-B (OPAL logo +word "Intializing")
Try to charge it for at least 8 hours, and also try this website:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2200
