SOURCE: haier air conditioner
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=1797 Hope this helps! ;)
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
SOURCE: Have an haier model number hwr08xc7 window air
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: I have a Haier 5,200 btu air conditioner that
E-1. Indoor room temp sensor defective. replace it.
The E1 code is an error code that appears on the LED temperature display of some digital air conditioners. The error code could mean anything from dirty air filters to a damaged room thermistor, a safety connected to your thermostat that detects room temperature. Troubleshooting the cause of this error code may improve your air conditioner's performance
