SOURCE: Error C50 on Lexmark X6170 printer
The ultimate permanent fix for the x6170 printer would be to purchase new cartridge snap-down levers (the levers that snap down inside the dell printer to hold the cartridges, blue for color and black for black). If you purchase snap down levers for a Lexmark printer series X5100 or X6100 or Z55 or Z65, the little guide peg inside the snap lever would work with an unmodified 83 and 82 Lexmark cartridge. All Lexmark did for Dell to make the Dell unique, was to put special Dell snap levers on the printer. I considered breaking off the little guide peg on the snap lever, but decided against it as it appears to help hold the cartridge in alignment
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
SOURCE: how to reset lexmark36 ink cartridge
try to reset ur printer
press and hold on power button for about 20 sec then press hte power button again
SOURCE: Lexmark Pro 705 won't let me print after refilled
If you refill the regular lexmark 100 ink cartridges, you will not be able to use it because there is a rfid chip that track the ink usage. you will need to buy the 100a type which will let you print if the ink level is empty. since you have refill the 100 ink cartridge, you can swap the 100a chip to your 100 cartridge.
SOURCE: My Lexmark prevail pro 705
This article on How to Troubleshoot the Vizix Ink Technology will help fix print quality problems on your printer. To run the Deep Clean Printhead function on your printer -> on the printer operator panel, press Setup -> Maintenance -> select Deep Clean Printhead. Your printer will then print the test page. Hope this helps. Thanks.
