I replaced fuel lines on my feather light xt200 weed eater and now I don't know which line goes where?
The longest, and sometimes smaller in diameter of the two fuel lines, goes from
the carburetor to the bottom of the tank. Leave enough slack in this
line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The
other
fuel line goes from the primer bulb to just inside the tank,
(about an inch). make sure that you get the right size fuel lines. The
plastic coupling goes on the end of this line, inside the tank. This
keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an
angle. They will feed much easier into the holes. You can than cut them
off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
