Motorola MC75 Logo
A
Anonymous Posted on Jun 25, 2014
Why is mc 75 dead - Motorola MC75
  • Official Brand Answer 3,100 Answers
  • Posted on Jul 25, 2014
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
684838
Points
13487
Contact Motorola Solutions http://www.motorolasolutions.com/support
I have a chrysler pt cruiser 2008 model bought second hand. clutch had always felt stiff anyway now my clutch feels loose and wont go into gear
bad MC and or slave
fluid low<
manual transmission clutch pedal dead.
the reservoir full is first. MC fluid. if dry bingo , got leak for sure.
2002 cabrio glx there are no fluid leaks on the brakes, reservoir is full. brake pedal hits the floor and there's a clicking nois in the dash
no fluid landing on garage floor or down sides of tires inside viewed./
no fluid down inside or outside firewall , right? did you look first.
fluid in MC reservoir is full. and does not drop day to day ever?right?
no,no,no,no .and full. so.....
BRAKES 101 , modern
1; when did brakes work right last week , last year or?
2: fuses check all fuses first. ok?
3: ABS does not render real brakes dead, if ABS dies !
the brakes actual are now back to say 1995 and no ABS years.
if ABS is dead, say power (12vdc) is dead. so...
this is called failsafe by me.... the system regresses to just brakes.
4: if he MC is bad this does MC dead. a dead MC can have seals inside bad and leak inside not seen by man, and renders it dead. or super weak or pedal creeps top the floor....
this is not to say and old car 20 year old and abused, he ABS modulator is train wreck inside packed up in RUST and so bad it blocks bypass circuits and fails hARD. (true damage here is unlimited in rust mode)
abuse means not refreshing brake fluid every 2 years. (flushed with fresh DOT fluid) the fluid is hygroscopic ! , it eats water/humidly every day of its life. then rust things in the system. (unlimited damage possible end to end,.
I purge mine every year. (can save $1000+ later)
why not go to a brake shop and get it fixed. towed.
it is unsafe on the road , driven.
Hydraulic CLUTCH release bEARING.
no year TOLD AT ALL 2001 TO NOW, 22 YEARS MADE
WE CAN NOT GUESS ENGINE OR TRANSMISSION OR YEARS.
THE VIN CODE ALSO TELLS YEAR AND ENGINE,.
iHAVE SEEN ALL FAILURES AND FIXED THEM ALL !
FOR AGE/WEAR CAUSES OR RACING BOTH.
i CAN ONLY ASSUME WHAT WAS DONE.;
NEW FULL CLUTCH KIT, PP, DISK,THRO/OUT BEARING, PILOT BEARING, SLAVE AND A NEW CLUTCH MASTER CYLINDER?
no? forgot MC did you>?
YOU DO KNOW THAT MC AND SLAVE BOTH WANT TO FAIL TOGETHER, (CORROSION INSIDE)
AND BLEEDING IS HARD, BUBBLES FLOAT UP AS BLEED.HAPPENS( a small war here)
AND GRAVITY BLEED HERE IS HOPELESS. sorry.
TOP END PRESSURE BLEEDING WINS. OR LOTS OF WORK DOING IT WRONG.(the lines are up HILL and bubbles float up)_
VACUUM BLEED CAN WORK IF HAND PUMP IS AGGRESSIVE.
meet MASTER cyclinder MC>
EVER SEE OWN ANY MC CAN FAILs.'?
1st things.1st. (ive also seen pedals cracked so bad up top MC does not move.) looking at it is the cure here. easy as pie.
THE PEDAL TO REAR OF MC, MUST HAVE GAP CLEARANCE
OR THE MC CAN NOT RECHARGE ON THE UP STROKE.
the MC bore has recharge port that must not be blocked, pedal up.
NOW LEARN MC GUTS INSIDE
THERE ARE 2 SEALS OR MORE. ONE OUTSIDE STOPS LEAKS, THEN 1 OR 2 INSIDE, ALLOWS IT TO PUMP AND MAKE PRESSURE, IF THIS INSIDE SEAL FAILS (UNSEEN BY HUMANS LACKING SUPERMAN XRAY VISION) THE MC IS 100%^ USELESS
PUT IN A NEW MC, AND SLAVE WAYWAY BEFORE THE MAIN CLUTCH, TRANNY PULLED.
REAR OF FIRE WALL LEAKING FLUID AT MC/?
SEE SEAL ON PISTON , CENTER HERE IT IS BAD.
SEEN HERE JUST ABOVE FIXING NUT.
https://www.howacarworks.com/illustrations/clutch-master-cylinder
see my drawing
seal 7 fails MC is 100% dead
blue arrow right some free play must be there.
purple arrow left is the charge port, if block MC is dead.
if no free play charge port is dead.
this is 1st things 1st rules. or the whole system goes dead.
the rear seal here 9 only stop leaks down both sides of the fire wall.
I got this from Superman , (xray vision)
mc1-undefined-undefined-0.jpg or the spring 4, rusted to nothing but dust (iron oxide)
What are the changes in Medicare for people over the age of 75?
You should have the new yearly booklet MC just mailed, all the changes if any are in there.
How do I lock or hide an icon on the Motorola MC 75?
somewhere big with lots of stuff on top and it's at the bottom
Top Motorola Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
