Re: How can I fix paper feed problems for hp 2140 fax
Clean the roller and separation pad in the paper pick up area. Use a rag w/ soap(just a little w/ hot water or use SANDED PAPER and gently do circular move to GIVETHE RUBBERA STRONGGER GRIP or replace it.
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
try copying blank pages. If it feeds the paper, then try faxing again. If it does not feed the paper, then open the feeder and clean the rollers and the separator pad. You can use a coffee filter moisten with distilled or bottled water to clean them.
Try copying blank pages again to check if it feeds the paper.
it will give you a break if the tires are not worn out. Look and feel if they are smooth, if they are smooth and shiny then replace otherwise clean with alcohol.
