Want to sync iPhone music to iTunes, you can't miss this post, How to Transfer Music from iPhone to iTunes Keeping Playlists More
Try for these steps :
connect your iPhone to iTunes .
on the computer select your iPhone.
click music> syn Movies
click option> syn option for any other
click apply to sync your iPhone at lower right bottom.
For more help https://www.apple.com/support/iphone/syncing/
and need any technical help Mac Tech Support .
SOURCE: iphone 2g wont sync
Please look here:
iphone Troubleshooting Assistant
http://www.apple.com/support/iphone/troubleshooting/phone/
Reset and Restore iPhone to Original Default Factory Settings with Recovery Mode
iPhone display freezing?
iPhone doesn’t detect by or appear in iTunes? iPhone cannot sync with
iTunes on PC or Mac? Cannot make or receive calls, send or receive text
messages, or access email or the web? Or worse, iPhone simply won’t
turn on and does not respond to tap or button press? If the problem
still persists after you have reseted the iPhone, or tried various iPhone troubleshooting,
it may be worthwhile to invoke recovery mode to restore iPhone to
default factory settings, the original state as when you first received
and unwrapped the phone.
Restoration of iPhone to original factory defaults will likely to fix
all problem, with the downside that all data and information stored on
your phone will be lost. Normally iTunes will make a backup
automatically when you connect and sync the iPhone with the program,
however, it’s still a good recommendation to copy out and backup
everything that you may need on the phone before proceed to restore the
iPhone.
To restore iPhone and reset the phone to default factory settings, follow these steps:
http://www.mydigitallife.info/2007/10/04/reset-and-restore-iphone-to-original-default-factory-settings-with-recovery-mode/
SOURCE: iphone only see apple logo and itunes logo in a dark screen after
If it got wet, you can bring it to any Apple Store. Nine times out of ten they will replace it for $150 to $200 dollars. Unless they determine it is a manufacturers defect and you are still under warranty, then you want have to pay anything. they will usually just replace it for you.
Otherwise, you may have to pay up to $200 for a replacement.
Hope this helps...Let me know...
enov8
SOURCE: Error code #13019 iphone not syncing w/itunes
I googled this question and found out a lot of people are having this problem. Check this thread out for the solution. It worked for me.
http://support.apple.com/kb/TS2830
SOURCE: IPHONE STUCK ON USB AND ITUNES SCREEN CANNOT CHARGE
It's sounds like your iPhone is stuck in recovery mode
Try this
SOURCE: apple iphone A1203
Hi eveyrone I 've got an old version of Iphone A 1203, accidentially I upgraded it to 3.2.1, now it does not support my simcard. Its original software is 1.1.4 how i can downgrade it to 1.1.4 or is there any ther solution do solve this problem please help me it's urgent
