You take off the front assembly, un-clip the bottom assembly where the brushes are and there are 3 different heights of the brushes just rotate it and continue to use unless you have already used all 3 sides, I, II, III are the options make sure both sides are on the same, refit back into assembly and make sure you clip the bottom back together and them replace back on to machine
SOURCE: changing a belt on kirby G6
I have written an online guide to help with this issue. Click on the link to view the guide. Hope this helps... Marci
SOURCE: Motor is making blue sparks.
It's the brushes for sure!!! My switch repair guide will get you down to the carbon brushes easily...
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
marci
SOURCE: owners manual for kirby g6
The Kirby G6 Vacuum Manual is available for free on this site: http://ubermanuals.com/product/kirby-g6-8499 .
SOURCE: Can NOT get Kirby G6 shampooer system lowered to use
take the attachments off and see if you can lower it then..if so .lower the vacuum and put the attachmens on then try
SOURCE: Kirby G6 - won't power on
Check the cords two wires with an OHM meter for continuity replace if you get a reading showing OL The ground wire you can forget about this test
If any sort of numbers appear in the meters display the cord is good
Replace the switch instead
Hope this helps...
Marci
