I can't get my plotter to print. Every time I try to print something it either does not respond or it prints a test page, blank page, or page I've already printed. I've disconnected and reconnected the plotter to no avail. What does error code: 22550 mean and how do I fix it?
It would be helpful to know the exact model number of your printer and the software level. If this is a PW300, it is an Initialization Error. Something is out of place that is not allowing the printer to start up properly. Opening and closing the lids may temporarily solve the issue but if it keeps on returning without having jams, there is either a sensor problem or the code level may need to get upgraded. New code levels have fixes that prevent false jam indications.
SOURCE: I AM GETTING ERROR CODE
Error 0501 is refer at low toner concentration problem.
I suggtes re-fill new toner and then off and on main switch some time, if the problem persists then you need to check the toner motor.
Maybe a clue as to the manufacturer might get you some respoonses. Want to fix something? www.manuals4you.com & www.justmanuals.com
Keep us updated; hope this helps
Not sure what the error code is but if you open & close all covers it seems to clear.
