If a
RANGES
\r\nNamed Ranges. SheetLevel Named Range, Named Constants, Named Formulas ,Relative Named Ranges ,Dynamic Named Ranges ,Advanced Dynamic Named Ranges .
\r\n
Working With Ranges. FindLast cell/row/column etc.
\r\n
Formula Reference Changer. Absolute to Relative etc.
\r\n
SpecialCells Method\r\n
Excel Named Range Manager $
\r\n
OFFSET RANGES VBA\r\nReturns a Range object that represents a range that?s offset from the specified range. Read-only.
\r\n
expression.Offset(RowOffset, ColumnOffset)\r\n\\"expression\\" is required and should be a Range object.
\r\n
\r\nRowOffset: Optional Variant. The number of rows (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset downward, and negative values are offset upward. The default value is 0.
\r\n
\r\nColumnOffset: Optional Variant. The number of columns (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset to the right, and negative values are offset to the left. The default value is 0.
\r\n
\r\n
Example\r\n
Sub OffsetMe()\r\n MsgBox Range(\\"B2\\").Offset(RowOffset:=-1, ColumnOffset:=2).Address
\r\n
End Sub\r\nIs the SAME as;
\r\n
Sub OffsetMe()\r\n MsgBox Range(\\"B2\\").Offset(-1,2).Address
\r\n
End Sub\r\n
OFFSET FORMULA\r\nReturns a reference to a range that is a specified number of rows and columns from a cell or range of cells. The reference that is returned can be a single cell or a range of cells. You can specify the number of rows and the number of columns to be returned.Syntax = OFFSET(reference,rows,cols,height,width)
\r\n
\r\n
Examples\r\n=OFFSET(C3,2,3,1,1) Displays the value in cell F5.
\r\n=OFFSET(C3:E5,0,-3,3,3) Returns an error, because the reference is not valid.\", \"style=\\"background: #FFFFFF;padding: 2px;font-size: 10px;width: 550px;\\"\");" style="FONT-STYLE: italic" onmouseout="GAL_hidepopup();" href="http://www.ozgrid.com/forum/autolink.php?id=5&script=showthread&forumid=8">cell is formatted as Text, then it will display the #### when the text is over the limit. Reformat the cell to General and the text should again show.
Right click on the cell, click Format Cells, under the number tab, choose General.
Also, this ####, will occur is the cell width is to small.
