Televison & Video Logo
A
Anonymous Posted on Jun 24, 2014
Bt vision forums
I need a code for new BT black remote (purple & grey keys)using Samsung LED UE40EH5000K 2012 tv. None of the old codes work.
3 Related Answers
Anonymous
  • 310 Answers
  • Posted on Jun 20, 2010
SOURCE: i need the remote code to work the volume button
good day if that remote you have the original on your tv , no need to search a code, code only apply when you using the universal remote. maybe your remote needs cleaning the board, so that all button will function
Raj Patel
  • 1042 Answers
  • Posted on Feb 14, 2011
SOURCE: I have just purchased a
Try the following links:
http://bt.custhelp.com/app/answers/detail/a_id/13573/~/programming-my-black-bt-vision-remote-control
http://bt.custhelp.com/app/answers/detail/a_id/13572/~/programming-my-silver-remote-control
pistonstone
  • 18 Answers
  • Posted on Aug 09, 2012
SOURCE: celcus bt vision code?
The remote comes standard with the code 0000. with my celcus TV this controls the volume and mute but not the on and off. Better than nothing...
2answers
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Got the new shape bt vision remote control but cant find the code for my blaupunkt tv can you help
Try these codes. Hopefully one will work.
034,118,119,138,189 if no joy then refer to your TV manual and look for a code there.
Bush tv remote code bt vision
The universal remote control codes to check with Bush brand TVs are 1067 1356 0744 0067 0698 1682 0248 0193 0379 0039 066 0401 0265 0312 0385 0393 0404 0294 0391 0517 241 0238 0247
1586 0728 0611 0324 0582 0586 1930 938 0808 1289 2012 1278 1712 1761 1196 0617 1338 0009 0668 0036 0218 0037 0163 0349 0272 0282 0355 0371 0235 0374 0519 0698 1037 0363 0264 0361 0487 0208 0217 0581 0294 0284 0556 0714 1900 1904 1908 0778 1668. http://electrohelponline.blogspot.com/ Check this link for more if you wish.
Celcus bt vision code?
2helpful
I have an e-motion tv and am unable to set my bt vision controler up as can't find a code
Same problem solved through patient "trial & error" ... for my e-motion TV, the BT Vision remote works with code "0081"
To program the BT Vision remote, instructions can be found at:
We have a schneider tv and a bt vision box we have used a grey remote from bt but we had to have a new remote as ours went faulty we have tried all the codes from bt but unable to programme the new one to...
The remote control should have come with a leaflet/booklet containing a table of figures; these are the codes you need for your tv.
Failing this, check the leaflet/booklet for instructions on how to search for the code, using a key sequence on the remote; this is a long, drawn out process, but it may just work.
If all else fails, try using google to search for any web pages that may offer you the necessary code.
It might be worth the time involved to search the web for an answer.
Beyond that, contact the manufacturer of the remote control & ask them for the correct code.
In my experience, there are only a small number of tv manufacturers whose products are difficult to use with universal remote controls, but Schneider is an obscure make, & if it turns out to be not possible to link up the remote control, you may want to consider buying a new tv, but check that it will work with the remote control, before buying it.
Hope this has been of some help to you.
Thanks,
Steve.
4helpful
3answers
Bt vision remote
www.remotecodelist.com .....................................T.
Remote control
the code for the bt.vision box remote to work a durabrand tv is under the emerson range the code i used was 004 it works fine
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
