try this one
How to Completely Reset Your RCA RCT6103W46 Android 4.2.2 Tablet
Follow the detailed instructions below on how to completely reset your RCA RCT6103W46 Android 4.2.2 tablet.
Step 1. With your tablet turned off, press and hold the volume down (-) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.
Step 2. Next, press the volume up (+) button. You should then see the screen below.
Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.
Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.
Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.
[img alt="" src="http://www.rcatablets.com/sites/default/files/step5_4.2.2.png" >6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished. Congratulations, you have successfully reset your RCA Android 4.2.2 tablet.
goodluck
