My tv-p42v20z has mysky, dvd, vcr, and stereo connected. I wish to connect a surflink media unit where do I find a spare audio out points that will operate this unit with out unplugging units already connected.
SOURCE: No volume at times
I fixed the problem by throwing the TV in the garbage, and buying a new one. (I received no answers from "Fix Ya" members as to instruct me how to attempt to fix the problem, so I solved it the only way I knew how!)
SOURCE: connecting tv/dvd combo to reciever to obtain surround sound
look for a connector that reads "Optical"..if none, then not supported.
SOURCE: connecting VCR/DVD combo
If you are able to you can connect to the RF connector (F Type Conncetor) on the TV. This should work. The layout is from the VCR (RF to TV) to the TV antenna F type connector from your Cable box to the Antenna in of the VCR that way you have cable through the VCR, and access to you VCR and DVD all controlled by the Cable and VCR remotes (set TV to Channel 3, set VCR to Channel 3) and use the Cable box as the tuner, Use the TV remote to switch between Cable and VCR inputs then use the VCR remote to switch between the VCR and DVD input.
SOURCE: can I connect a dvd player to a dvd\vcr combo
I am not sure I understand why you would hook a dvd player to your combo.You should just hook your magnavox directly to your tv.
SOURCE: DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
