You will need a 5/16 nut driver, phillips and flathead screwdriver. Remove endcaps on rh and lh side of console by pulling from the top towards you. That will give you access to phillip screws located beneath. Disconnect the lid switch under console, and unlatch gold colored clips attatched to rear panel and cabinet with a flathead. Use a phillip screwdriver to remove lid switch from cabinet and 5/16 nutdriver to remove ground screw underneath main top. Unclip the lid switch from under top. Reverse process to install.
