If you forgot your lock code, then send me an email message and will tell you how much to have it unlock. A long time ago, Nokia use to do it free, but now they are one of the most expensive. I will go ahead and check it in the mean time.
Im sorry, I mistaken gave you the wrong infor because you listed you IMEI number. With the Nokia 1108 you dont need the serial number to unlock the keypad. You only need the serial number if you are doing a Network Unlock where you are able to use your phone with another carrier. Here is how you Password Unlock your Nokia 1108. This can be a little technical, so follow very closely. 1. Turn off the phone. 2. Press all 3 buttons (Menu, Camera & Volume Down) simultaneously or together or at the same time. 3. While have all 3 buttons de-pressed then press the power button while you have the 3 buttons holding. 4. Once the phone comes on let go the power button. 5. When you see the Nokia logo, then let go all the other buttons and let the phone does it thing.
Remember, when you do this to your Nokia 1108, everything will be lost or erased in your phone, so make sure you backup all the data or phone numbers before doing this.
SOURCE: my keyguard code in security
on your phone dial i believe 611 it takes you to your carrier or you can call direct to your carrier from home phone these processes are extremly compelling and the walk threw you need a map to get threw
the carrier has that map infront of them they would be the most help
SOURCE: i forgot my keyguard code in security code
i forgot my security code of nokia 1108 it's serial no is355030002383956
SOURCE: forgot security code of nokia1108
u must take it to a near by nokia care or contact me at 9999-916-148
SOURCE: forgot my keyguard code in security
i forgot my security keyguard on my Nokia 6300 IMEI: 352939023555751
*#7780# Restore factory settings Regards Mohit
