Just logout from Netflix. If you can't find the logout, then turn off the TV, remove the internet cable from the TV or where it is connected.
If using Wifi, then disconnect the TVs Wifi.
If you can't find or manage any of this, then:
Turn off your Router/modem for 5 mins. Make sure there aren't anything important using the internet connection, before you turn off the router.
i just asked this question. logging out doesn't help - when i sign in with the email it goes right into their profile and doesn't give me the option of changing profiles.
Try have a look at their support page for Profiles:https://help.netflix.com/en/node/10421
Good luck
thanks
SOURCE: changing profiles
are u insert the sim first insert the sim and change the offline to general if it is not cange then u may change sim emif
thanking u
santhosh +919993334004
SOURCE: I can't change the user
all you have to do is...
get the headset of your phone connected to the phone, try to make a call with it and see if it you can hear and speak clearly,
if it doesn't sound clearly, then you'll know that the headset-port which is soldered to the panel is corrupted and needs to be replaced with a new one.
go to a recommended specialist for the headset-port replacement.
I KNOW THIS WOULD BE A NOKIA PHONE.. NEXT TIME SPECIFY THE MODEL AND MAKE OF THE PHONE.
hope this works...
SOURCE: nokia1208, lost most themes, can receive call,
Hello.did you restore your phone ? Open menu >> Setting>>Restore factory setting>> Restore it, it will surely work normally.For details follow this link How to set ringtone when unable to set in Nokia 1200,1202,1203etc. Good luck
