Remote control not working to turn back on cannot manually use side on button for TV screen to come on just stays in standby
SOURCE: remote control code
Dish Netork does not have the code for Olevia
but you can scan for the code using the infformation
here
Remote Code Power Scan
If your brand is not listed, use the following procedure to scan through all codes.
If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
1. Turn ON the unit you want to program the remote to control.
2. Press the Mode button on the remote until the appropriate mode light is flashes
3. Press the Address button. The mode light will start flashing slowly.
4. Press the Power button. The mode light will stop flashing and stay lit.
5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8. Turn the device back ON by pressing the Power button.
9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10. If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
SOURCE: Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
SOURCE: Power issue with Olevia LT23
this is bull do...The same thing happens with my TV I Have the Olevia 23" and the power will not turn on.
$700 shot, who cares about the rebate when it works on a short while...
SOURCE: Remote Control Code for Element LCD TV -- & Direct TV
We cant find our original element remote control. I just tried 10178 on the direct tv remote control and it worked YEAH!!!! We just can't do the screen size edit thing with it :(. Might still have to order a replacement element remote. This works for now. Thanks.
