I spilt some water on my keyboard and only a few keys work incorrectly.they type double letters and numbers that are not the keys typed.
Get the keyboard...
NEW Laptop US Keyboard For Acer Aspire 5560 7851 5560 SB613 5560 7809 US...
replace the keyboard...
Repair Acer Aspire 5741G 5742Z 5736Z 5336 5560 Easynote TK Disassembly
SOURCE: acer keyboard messing up
Fantastic! I was just having the same problem when I read this article and pressed FN+NumLk(F11), then the keys started to work properly again.
SOURCE: cant find the number lock key on my acer 6920 laptop
I think for your laptop the number lock key is a second function... Try holding down the function (Fn) key and pressing the F11 key, hopefully that will turn your number lock on/off.
SOURCE: laptop keyboard typing gibberish
We all have those kinds of days from time to time <Grin>. The best solution that I have found is to smack myself on the forehead and continue on with the day!
Speaking of which,have a super day and keep smiling!
Ron
SOURCE: how to replace a acer aspire 5735 keyboard
Here is the factory service guide that explains complete servicing of the laptop. Make sure to save a copy for yourself, the file is free to use.
http://tim.id.au/laptops/acer/aspire%205735%205735z%205335.pdf
SOURCE: NETBOOK KEYBOARD NOT WORKING
You better check first if it is the keyboard on your netbook is the problem.
Below is the steps that you can use:
You need to use external keyboard ( typical keyboard usually use for desktop PC ). plug the external keyboard to the port where you can plug the cord of the external keyboard cord going to your netbook
Then, if the external keyboard will work the best thing to do is to bring your netbook to the support center near in your area to check if the keyboard of the netbook if its still working properly and to find out if you really need to purchase a replacement for the keyboard of your netbook
If the external keyboard will not work you also need to go bring your netbook to the support center to check the parts that is connected in your netbook.
