Bad valve seats. At idle or overnight the seals will leak oil past them and into the combustion chamber causing smoke . This is the most common problem with smoke. Can also be worn piston rings.
Very common problem you have here Try this when running the mower be sure that after starting you pull the throttle lever back a bit so that you are not in the choke position
IF you are choking the engine you will get oil **** through the engine and sooner rather than later oil in the muffler
blue smoke out of 1.8 turbo its allways bad oil seal inside turbo.need new turbo or rebuild OEM. with 24 years experience working with vw never seen single headhasket go bad on 1.8 turbo engines.blue smoke its 100% turbo every time
try by unplugin the oxigen sensors, specially if this car has been in an mufler shop for catalitics or mufler repairs, sometimes they are not to carrefull and might damage an oxigen sensor, this sensor are located on the mufler pipe, and they look similr to an spark plug.
I
recommend headers, with 2 1/2 inch true duel pipes, feed it to an aftermarket
cat, a must have, with all O2 sensors, then run Your pipes into some cherry
bomb glasspacks, then run it out to either comming out just in front of or
just behind the tires, with a turndown right before the quarterpanel wall.
