SOURCE: unbalanced load cabrio top loader
i am on line now- we checked with a level and its right on... i have been washing on the normal cycle and then using the drain/spin cycle to spin out as much water as i can..that cycle even displays the ul code...its always displayed somewhere between 12 mins left and 7 mins left...i dont know if that has something to do with it??
SOURCE: my whirlpool cabrio washer has ld code. have
Please see the following Whirlpool service manual for the Cabrio washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96˝ ?
• Is the pump running? If not, see TEST #7.
SOURCE: what tools do i need to remoove drain pump from
If you remove the pump turn it upside down to shake out the coins Its secured by two screws cross head or philips......Remove the 2 hoses use an old towel to mop up the water from it ...quite straightforward.Good luck...
SOURCE: My Whirlpool Cabrio washer has some coins trapped
They are not in your agitator. they are in the pump on the bottom left if you are standing behind the machine. Be VERY careful. That litle pump seems to be the beginnig of many leaking problems.
SOURCE: my whirlpool cabrio top loading washer with corner
You have to disconnect all wire connectors, inner basket, both pumps & Then unclasp the 4 shock rods then remove the whole inner assembly. Then turn the inner assembLy upside down & every which way until they all fall out. Like shaking quarters out of your piggy bank.
