I wish I could have tested it first but you can still try the Shotgun method.
Your options are.
Contact HP.
http://welcome.hp.com/country/w1/en/contact_us.html
Or download these files.
https://www.dropbox.com/sh/zu4kdgxm052l87d/AAAMi-kfX4AVH8oTCbsOM4X9a?dl=0
Insert clean USB flash drive.
Then run USB Image tool.
Choose the flash drive then click on RESTORE.
After restore remove flash drive.
Insert flash drive into locked laptop and boot. "If HDD is installed remove before booting."
At C:\OUTPUT type CD.. "Then hit enter"
Type HPBR "Then hit enter"
First thing is to save your settings.
Select #3 re-program.
Press "S" to save system information.
Type HPBR and hit enter.
Since your model is not listed select "SHOTGUN."
After reboot repeat "SHOTGUN" a second time.
Let me know the result so I can update my list.
Some instructions here. "If you cannot boot from USB there are instructions to make a bootable HDD."
http://mazzifsoftware.blogspot.com/2014/01/hp-bios-unlock-for-dos.html
More help here.
http://forums.mydigitallife.info/threads/49497-HP-Probook-Elitebook-BIOS-Password-Reset-Utility?s=ad18a86dbbaf34999e22b1225a42a395
REO
I must inform you that these services are not endorsed by HP, and that HP is not responsible for any damage that may arise to your system by using these services. Please be aware that you do this at your own risk.
Posted by Anonymous on Jun 23, 2014
why post to 2014???????
and is wrong. for any probook or elite book
only HP can fix this, BY DESIGN !!!
http://www.pcdied.com/passwords.html
Dadan Hamdan
Nice way to brick a good PC, I have ever seen.
why do that,?"evil"?
the correct answer is ask HP for help
there are 4 ways that work at HP.(history all)
1: old PC jumper resets, not yours.
2: RTC coin cell out battery main, and ac power pack removed, and put all back and its reset. (old pcs only)
3: HP has back door to BIOS passwords resets
on vast numbers of PC's before the PITA UEFI rules are enforced (window 8 up) not yours.
4: last are the newer pCs HP has direct intervention way to reset it , to ask them,
sorry Fixya IS NOT HP, and the ask for your
PCs service tag and UUID, serial #
then then send you a reset program that only works on YOUR PC, nobody Else's.
there now, you know the correct ways all
this old post the
OP has contradictory facts.
HP ProBook 4510s
then says hp 6540b
but is a probook and probooks
must be #4 above reset.
with HP direct help, that is why they call it a probook, (cost more too just for this rule)
so hacking it does not work and only bricks the PC.
also related is if the disk is encrypted
and if the full security package HP is enabled,(and for sure was installed new)
all that matters, or YOU WILL BRICK that PC.
end BIOS resets. HP only. by year and model.
always ask here first. not fixya,
the real HP is here, and answers correct.https://h30434.www3.hp.com/
SOURCE: how do i reset bios password on hp nx6125 s
http://www.tech-faq.com/reset-bios-password.html
I would try this link. It gives manufactures backdoor passwords that may work. And if not, it details other ways.
SOURCE: how can i reset a
To reset the BIOS password on your HP notebook read the information from this link.
SOURCE: i want to remove bios password on my laptop HP
RTM - Read the manual (User Guide on HP website)http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodTypeId=321957&prodSeriesId=4095215I found this:To delete this password in Computer Setup, follow these steps:
1. Turn on or restart the computer, and then press esc while the (Press the ESC key for Startup Menu)
message is displayed at the bottom of the screen.
2. Press f10 to enter BIOS Setup.
3. Use a pointing device or the arrow keys to select Security / Change Password, and then press
enter.
4. When prompted, type your current password.
5. When prompted for the new password, leave the field empty, and then press enter.
6. Read the warning. To continue, select YES.
7. When prompted to type your new password again, leave the field empty, and then press enter.
8. To save your changes and exit Computer Setup, click Save in the lower-left corner of the screen,
and then follow the on-screen instructions.
or
Use the arrow keys to select File / Save changes and exit, and then press enter.
Your changes go into effect when the computer restarts.
Using
