The AVIC D3 is not pioneers best. The navigation side of the unit is wearing out. The slider slot in the dvd and other moving parts are wearing down fractionally and that is all it takes for the unit to no longer read the high density map data discs. The map disc is a dual layer 8.5gb disc and it is just about max out. (The disc must be in the unit for the navigation to work.) This is a lot of information and the unit must be able to read every bit of data on the disc or it will error out. All it takes is the fractional wear to mess up the tracking of the laser over the disc and cause problems reading the data on the disc. When the unit spins and spins, it is working hard to read something on the disc and will eventually error out if it can't. Also a fingerprint or tiny spot on the disc will prevent the unit from reading the disc. (Clean with a drop of water and soft cotton cloth even if it looks clean.) The data is information or instructions telling the unit what to do, and if it misses any information it will go crazy and error out. This is very different from music or video/movies that just play and if a spot is on the disc it will just be a fuzzy picture or static from that spot. If you have a disc your system likes, take care of it. I say likes because every disc has fractional differences in data location on the disc. (This is tolerance) That fractional difference could make or break the ability of your unit to read the map disc. So one possible fix is trying different disc to see if your unit will like one of them. Still eventually this also will die. These units are beyond their life cycle and the dvd drive is operating on borrowed time. I hope this helps.
SOURCE: How do I set the clock on my Pioneer AVIC-D3
I live on the east coast and had to change my time to be all the way out to one end and manually i have to turn on or off the "summer" time setting, which is kind of like DST.
SOURCE: Ipod problems with Pioneer AVIC-D3
Do you have an ipod module or are you using ibus-to-rca cable to connect your ipod to the D3? In order to control full ipod functions by touch screen you need the ipod module, hence the D3 says ipod control ready not ipod control built in. Let me know so I can pin point the problem.
SOURCE: how do you reset the pioneer avic-d3
CLICK HERE for the Owners manual, and find on PDF page 22 the PROPER way to reset the unit.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: Hello. I am looking for the code for the dvd
Code? The parking brake wire needs to see ground to watch DVDs. You have to remove the yellow/black mute wire from the harness using a pick tool, then place that wire into the empty slot right above where it was, then ground it and the light green parking brake wire.
