Brother SE400 Computerized Sewing Machine Logo
A
Anonymous Posted on Jun 22, 2014
I cant get my needle to stay in sewing machine i put it in tighten the screw thing and it just falls right out
5 Related Answers
Anonymous
  • Posted on Feb 21, 2009
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Anonymous
  • 52 Answers
  • Posted on Jul 14, 2009
SOURCE: Needle holder fell off of machine
there should be an allen screw on the back side of the needle bar clamp push it up and on and make sure its as stright as you can get it and tighten down on the allen screw
RichSew
Douglas Plant
  • 222 Answers
  • Posted on May 27, 2010
SOURCE: needle will not stay in?
Buy a new pack of needles to make sure you do not have defective needles, if that doesnt work get a new thumb screw and if it still doesnt work you need a new needle bar.
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Dec 06, 2010
SOURCE: The needle on my sewing
when you put the needle in the needle clamp holder the flat side of the needle goes toward the back of the the machine when you tighten the needle clamp screw make sure it's holding the needle,,make sure you can't pull the needle back out of the clamp,, if you can something is wrong with the needle clamp or the screw
  • 7365 Answers
  • Posted on Aug 09, 2011
SOURCE: i have a two needle machine. i am currently only
the flat side goes toward the back of the machine. Yes, push it all the way up in the carrage, before tightening the screw.
also check the thread tension to make sure it's not to tight for the thread
also use a can of air in the looper area at least once or twice a month, depending on how much you use the machine
always keep the machine covered when not in use to keep dust out of the machine
Testimonial: "thanks so much for your very specific advice, i'll try this when i get home. :)"
My needle keeps falling out. I unscrewed the set screw, put the new needle in, then it falls out. I had just taken out an old needle by unscrewing the set screw and didn't touch anything else. Help
Be sure to unscrew the set-screw and extra turn and then insure you are pushing the needle all the way up before tightening it. Could also mean the set screw is stripped...
1helpful
How do I change a broken needle?
You need to tell us make and model when you post a question for us to give you a really good answer.
Here the generic way to replace a needle:
  1. Raise the needle fully.
  2. Look for a thumb-screw right where the needle joins the needle mechanism.
  3. Loosen the thumb-screw and catch the broken needle when it falls out.
  4. Put a new needle in the place occupied by the broken needle. Be sure the flat side of the needle is away from you.
  5. Tighten the thumb-screw.
Replacing a needle
All the machines I have had have a twist screw, right beside the needle, on the right of the needle. Raise your needle lever into the upright position, so the needle isn't in the machine. You use your thumb and first finger and turn the twist screw backwards. You can then pull your needle down and it will fall out of the needle holder. Insert a new needle, making sure the holes in the needle are front to back, not side to side, and tighten the twist screw.
I have a white superlock 534- I recently broke a needle and now I cannot load two needles. After unscrewing the screw- I try to load two needles and only the right will stay in--left falling out. If I load...
I have a White Superlock 534,the needle broke and I tried to change the needle and lost the screw,it is so tiny I cant find it,is their any way I can buy the same tiny screw.I like to have 2 needles.
2answers
3answers
Needle will not stay in? i install needle, tighten thumb screw and the needle falls out??why??
13helpful
3answers
Needle clamp fell off. got a new one, but need
I have an XL6452 and the same problem. I figured out that you can use a tiny screw driver (or an allen wrench might work). I tried using the screw that tightens the needle but it didn't seem to work. The screw looks like it just a hole. It took a lot of turns to get it loose enough so you can put it on. You will see it come out.
Once you get it on you can tighten it.
9helpful
Needle holder falls off, won't stay on. It's done this before but stopped for a while. I don't even see what holds it on there. I am so irritated with it.
My husband used a 5/64 allen wrench to reattach my needle holder. There is a small black set screw directly above the screw that you tighten to hold the needle in place. I just looks like a small black hole, but there is a screw in there. Use the wrench to tighten it and you should be good to go.
8helpful
Needle clamp won't attach to needle bar
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
