Vizio 55" M550NV Razor LED LCD HDTV, 1080p Logo
A
Anonymous Posted on Jun 22, 2014
What is function of a T-con board for a lcd tv
Electro Med Services
Level 3:
  • Vizio Master 6,694 Answers
  • Posted on Apr 18, 2016
Vizio Master
Level 3:
Answers
6694
Questions
Helped
1870591
Points
21433
TCON (Timing control board). Its drive the lcd panel.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
1helpful
Sony lcd has lines- vertical AND horizontal white lines
Yes, it's possible that the T-Con board in your Sony LCD TV may need to be repaired or replaced if it's causing vertical and horizontal white lines on the screen. The T-Con board is responsible for translating the digital signal from the TV's main board into a format that the LCD panel can display.
Before replacing the T-Con board, you may want to try some additional troubleshooting steps, such as checking all the cables and connections, performing a factory reset of the TV, and updating the firmware. However, if none of these steps resolve the issue, then the T-Con board may need to be replaced.
You can purchase a replacement T-Con board online or from a TV repair shop. If you're comfortable with electronics repair, you may be able to replace the board yourself by following instructions provided with the new T-Con board. Alternatively, you can hire a professional TV repair technician to replace the board for you.
Vizio LC470DUG powers on for 4 seconds than goes off--possible mother board
No such thing as a mother board in a TV set. Here is a list of the PCBs
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it may be time to start testing different boards to see if they are functioning properly.
Main Board
The main board, or motherboard, is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. This part is also sometimes called the main module or the A/V (audiovisual) board.
Power Supply Board
Another large and important board inside a television is the power supply board. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long, thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
Timing Control Board / Logic Board
The timing control board, known as the T-CON board, is typically only found on LCD and LED TVs. Plasma TVs, on the other hand, use a logic board. The functions of the logic and T-CON board are similar: each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixilation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
X-Sustain and Y-Sustain Boards
Also known as the X-SUS and the Y-SUS, the x-sustain and Y-sustain boards only appear in plasma screen TVs. The X-sustain board may also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The X-sustain board activates all the display lines at once, while the Y-sustain board addresses all the individual lines of display. When one board breaks down, it probably does not affect the functionality of the other. However, it may be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short lifespan anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
Buffer boards are also only found in plasma screen TVs. Connected to the Y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
1helpful
After a thunder storm i have sound, no picture, the tv powers up, the back lights are on, should i suspect a bad lcd screen?
Something else is going on. The T-Con board has no other function than controlling the picture. If there is a separate board for the led drivers, I'd suspect that one. The main board controls the sound.
Tv repair.for plasma tv
No screen boards found. Do you mean any of these?
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it might be time to start testing different boards to see if they are functioning properly.
Main Board
The main board is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. Main boards might also be referred to as a motherboard, main module, or an A/V board.
Power Supply Board
Another large and important board inside a television is the power supply board.. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
The timing control board, known as the T - CON board,, is typically only found on LCD and LED TVs. Plasma TVS, on the other hand, use a logic board.. The functions of the logic and T-CON board are similar, as each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixelation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
Also known as the X-SUS and the Y-SUS, the x-sustain and y-sustain boards only appear in plasma screen TVs. The x - sustain board might also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The x-sustain board activates all the display lines at once, while the y - sustain boardaddresses all the individual lines of display. When one board breaks down, it probably will not affect the functionality of the other. However, it might be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short life span anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
B uffer boards are also only found in plasma screen TVs. Connected to the y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
TV Boards Buying Guide
Vertical colored lines on entire screen, sound ok
Hi.
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
www.electro-medical.blogspot.com
2helpful
The colors of the tv are fine except for the blue, things that should be blue are green
The board that called the T-Con board it is could be dead.This T-Con board control the out put tv signal to the tv LCD screen panel.This T-Con board sit at the bottom in the middle bottom of the tv LCD screen panel. Take the connection out of the T-Con board .Tries clean the connection of the board with some rubbing alcohol,might fixed the problems,if not.Tries websites like Shopjimmy.com,EBay.com to buy a refurbish T-Con board for the replacement.
My tv screen is totally white audio is fine.
p { margin-bottom: 0.21cm; }
As you mentioned your tv have problem with the T con board. Normally in an lcd tv he t con board drives the millions pixels in the lcd panel in rows and columns. if any of the driver or a group of driver for rows and columns is fulty then the respected row or column will be missing in the picture.
This problem can occur under two circumstances fist is if there is any loose contact in the connections of the board. if so remove all the connection to the t con board and then reconnect it. There are total six connections in the t con board. Of which five will got the lcd panel and one will go to the mother board.if there is any loose contact removing and refining the connections will solve the problem. If not then you have to replace the T con boar.
Normally you can find the t con board in the bottom centre or top centre of the lcd Covers with metal cover or aluminium foil. I have added the picture of the t con board for your tv. I you need any more assistance feel free to contact me through fixya.
Ajin
4helpful
My 52ince LCD Sony Bravia TV is started showing 2 vertical lines on each side, but they go away 20 minutes after starting TV. What is wrong?
The tv board call the T-CON decoders board have problems,that why colors vertical lines are showing up in the tv LCD screen panel.The T-CON decoders board,this board sit wright at middle bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
2answers
LG 26LG30 Flat-panel TV have light flashes red and blue dont turn on. i need heelp
1. unplug it form the wall allow to sit for 30-60 seconds
2. plug it back in to the wall and try to turn it on
*if this does not work you might have a issue with the power supply or t-con boards. Please let me know ether way.
Please do be considerate and leave positive feedback and ratings for your answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
