Question about Troy Bilt 175HP Manual 42" Riding Mower
My troy biltwont move forward unless i rock it a little but if you let it slow down its same problem and it wont go forward in lower gears usually.also has ran a new battery dead
Troy bilt riding mower wont go forward unless you rock it and if you let it slow down you have to repeat,also wont move in lower gears only high ones.also has ran a brand new battery dead
    New Friend:
Check your drive belt it might be badly worn which would make it loose.
Posted on Jun 23, 2014
6ya staff
SOURCE:
boiler55
  • 12 Answers
SOURCE: NEED A DIAGRAM OF HOW TO ROUTE A BELT ON A TROY
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
Posted on Aug 13, 2010
rycgl
Roy Cagle
  • 1545 Answers
SOURCE: troy-bilt model 13AN77TG766 wont go
The manual probably won't be of much help with this problem. Your transaxle may have seized up or failed due to the introduction of water into it. A lot of riders have had this problem, especially the ones with the DANA manufactured transaxle. I hope this is not your problem, and that the problem is in your shifter linkage between the lever and the transmission.
I am continuing to look for the manual. In the meanwhile, here is your complete machine with All parts, diagrams, breakdowns and part costs included. Hope this helps. It is sometimes tough to locate manuals as you have found.
http://www.partstree.com/parts/?lc=Troy-Bilt&mn=13AN77TG766+Pony+%282006%29
Posted on May 21, 2011
Lloyd Carter
  • 153 Answers
SOURCE: can i get a diagram
without more information i can only give you a link.http://www.troybilt.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10001&catalogId=14102&langId=-1#Error
if this dose not help please contact me back with more info like model, make, year and I will do better.
Posted on Jun 05, 2011
SOURCE: I need to replace the drive belt on a Troy-Bilt 16S riding mower with a 42" blade deck and I do not have a model# or serial# on the mower (label under seat apparently came off at some point before I i
Lowes or Menards sell troybuilt they may be able too hook you right up.
Posted on May 05, 2012
mike butler
  • 6468 Answers
SOURCE: my pony troy bilt riding lawn mower engine runs great. but will not go forward but will go in reverse
check the pedal adjustment the rod might have backed off
Posted on May 31, 2012
Wont go into 3rd and 4th gear,all other gears no problem
Usually a shift solenoid causes this. If it drops out and quits moving forward until you slow down, This would be another internal problem.
Apr 10, 2016 | Kia Picanto Cars & Trucks
My MTD Yard Machine will not pull off unless it is in 4th gear or higher. And slowes down when i start to cut the grass. What is going on?
The problem is most likely the gear box. I would take it to a repair shop, unless the machine is very old, then just replace it. The belt would most likely be the cause of the slowing down when mowing and should be replace when the gear box is repaired.
Sep 18, 2014 | Garden
Troy-bilt troubleshooting
Sounds like you have an issue with a broken or off pulley belt.
Aug 06, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt troubleshooting
Check under your deck you could have something that is keeping your blades fro turning.
Aug 01, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt zero turn mower runs but does not move
Make sure the gears are engaged. There are 2 metal hooks on the rear of the mower, 1 on each side, if they are pulled out the mower is out of gear, make sure to slide them over so they retract back into the mower. If not the problem, sounds like either broken drive belts or the transmission isn't working properly.
Jul 02, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Shifter moves on big bear 350 but quad wont reverse now it goes forwards
for some reason you are not getting into reverse , there is no real reason it should stay in forward gears unless there is someting wrong with the shifter itself being in the wrong position this can happen take it off and reposition it and make sure your clutch is disengauging to shift gears , will it go into all gears or just 1 forward , ck into that and be a little more specific on the problem ,good luck
Mar 18, 2014 | Grizzly Big Bear Atv Maintenance Free...
Have a 95 suzuki sidekick had some work done on the wireing around fuel injectors now my engine light is on and it wont shift out of first gear.please help no money left
this should be a simple solution rock your vehicle forward then reverse on running engine
they call this trans lock usually happens on hills or pressing down the shifting knob
get a few friends to help push forward if cant start vehicle because in gear its like the old 4x4 hubs in order to get out of lock it needs to be rolled a little
my little 4x4 did same thing called a friend he told me same way to fix
Nov 09, 2013 | Cars & Trucks
Mower slips in and out of forward gear but rides perfect in reverse;What do I need to adjust?
Reverse is a different gear set than forward gears. Sounds like forward gear set has a broken tooth. Not an easy fix.
Jul 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Troy Bilt 175HP Manual 42" Riding Mower Logo
268 people viewed this question
Top Troy Garden Experts
Neil Hancock
Dave
Joseph Mueller
Joseph Mueller
Are you a Troy Garden Expert? Answer questions, earn points and help others
