Olevia LT37HVS 37 in. LCD HDTV Logo
A
Anonymous Posted on Jun 22, 2014
Bauhn 32" TV! red light is on, The remote is flat & I can not start using standby button.
  • Limuel Dela Cruz Nov 05, 2019
    Any update? I am stuck in the Standby light it wont turn on.
David Spradling
Level 3:
Top Expert:
  • Olevia Master 13,524 Answers
  • Posted on Sep 19, 2020
David Spradling
Olevia Master
Level 3:
Top Expert:
Answers
13524
Questions
0
Helped
929410
Points
28396
Try replacing remote battieries then unplug tv before doing that put batteries back in and plug tv in see if remote turn on if no check see if remote buttons stuck if ok try reset
Aron
Level 3:
Top Expert:
  • Olevia Master 2,586 Answers
  • Posted on Aug 12, 2020
Aron
Olevia Master
Level 3:
Top Expert:
Answers
2586
Questions
0
Helped
390153
Points
78544
Check the Batteries inside of the remote control for your TV to see if they needs to be replaced and put new batteries inside of the TV remote and see if it will work after having new batteries. If the remote is still not working with new batteries then the remote is broken and needs to be replaced with a new remote from your TV company. The TV name of brand should have an official company website and you could try and take a look for replacement remotes.
Low battery power can cause the remote to not work correctly or not work at all. Lift the back cover up and away from the remote. Remove and re-insert the 2 batteries. Replace the back cover on the remote, and slide down to click it back into place.
Pour a little bit of rubbing alcohol onto a piece of cotton and very gently clean the main board. You will be surprised to see how much dirt is built up on the main board. Now take all the other parts or pieces of your remote control and give them a good gentle wash using a tiny bit of mild soap. Wash all the plastics and also the rubber keypad.
2 Related Answers
Anonymous
  • Posted on Nov 06, 2008
SOURCE: Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Mvp4eva
  • 24 Answers
  • Posted on Dec 22, 2009
SOURCE: Olevia LT23 23in. LCD/TV
I had the same prob, but found out that the problem with the Olevia lcd tv's on most models not powering up is because of failure of capacitors on the power supply board that I do believe is due to excessive heat and lack of ventilation.
I took the tv apart and got access to the main board and just by looking at the capacitors I could tell which one were the bad ones..
I will show some pics that I borrowed during my repair, hope it helps as reference as it did to me.
I replaced the bad caps with new ones that I bought at a computer parts store.
Now I got my lcd tv back ON but this time I added a internal cooling fan for better air flow that will reduce this malfunction from happening again.
Hope this helps.
3answers
Remote code for Bauhn ATV-BA32DV2
bauhn p v r setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... bauhn universal remote control tv but i had vivo tv how ican set up that The universal ... ATV-BA32DV2, have done initial setup, but screen says have to scan ...
Remote code for BAUHN TV model ATV-19HED - TVs - Home theatre ...
forums.whirlpool.net.au > Home theatre > TVs
WhirlpoolDec 14, 2014 - I've mislaid the remote for this TV and I was wondering if anybody new how I could get hold of BAUHN remote IR codes. I've looked everywhere ... 32" (81CM) HD LED LCD TV $222
May 29, 2014
Bauhn 24" Full HD LED LCD TV with DVD
Jan 12, 2013
More results from forums.whirlpool.net.au
[PDF]32" (81cm) HD LED LCD TV
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
9helpful
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
2helpful
2helpful
2answers
Switch TV on then a blank red screen appear then a green and then a blue which then just repeats that sequence of colours every second. The remote control packed up working some month before. - 2 year old...
turn TV on, let the Tv cycle through the three colours, then using the remote press the menu button followed by the standby button. press standby button again and it all comes up working.
andy
2answers
I need a code for my sky remote for my sanyo tv in order to get the volume working It is a sanyo 32" Model CE32LD33-B-01
with the tv on and sky off, press red button & select together, remote blinks twice.press tv then standby repeat this action until the tv turns off. when it goes off press select. press standby again and tv should start. your sky remote should then work perfect. as a tip with tv on and sky off press tv then back up this should then go to the freeview setup and you can watch those as well for free
1helpful
My Daewoo LCD TV (DLT-32C3FTB) will not come off standby.
Common problem on power supply board, replace dried out electrolytic capacitors
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Top Olevia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
