Question about Drills
Dewalt 30 Minute Fast Charger does it work in uk 230v
    New Friend:
  • 44 Answers
Some battery can not be charged by fast charger, because this can damage the battery. You can think to replace it to a new charger, a 7.2V 9.6V 12V 14.4V 18V NI-CD NI-MH BATTERY charger for Dewalt
Posted on Jun 26, 2014
3 Suggested Answers
6ya staff
SOURCE:
Fred Yearian
  • 5603 Answers
SOURCE: Have a Plantronics Cordless phone with the
You may have FAILED to check that the polarity matched. Some have the pinpositive, the other the sleeve.
It is UNLIKELY that muchwas damaged beyond the power regulator in the base unit. Should be relatively inexpensive repair.
Posted on Dec 26, 2009
Repair Ahjoshe
  • 885 Answers
SOURCE: broken dewalt battery 18v lithium ion
When a Dewalt charger is showing a fast blinking red light it means the battery is no longer chargeable. It may be because of a bad cell or short inside the battery. Whatever the reason the charger will not charge the battery and it needs to be replaced.
Posted on Jan 30, 2012
Can I use the charger with the 220 in UK ?
Unless it is rated for 220-50/110-60, you will need the converter. Besides the 110V US plugs won't plug into the 200V UK outlets.
Apr 14, 2015 | Dewalt 12v Max - 20v Max Li-ion Battery...
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
Feb 28, 2015 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
18 volt dewalt lithium ion battery charger stopped working for no reason....
This can happen if the battery is too dead for too long. Keep trying to make it work like you have maybe 20-30 times. Or you can leave the battery in for a few days and let the logic chip do it's job. It should start working in a day or two.
Apr 25, 2012 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
I can,t charger my dewalt batteries , so is the fault with my charger
It is likely the fault is the battery and not the charger. To confirm this take the charger to any Radio Shack and ask them to test the charger or if you have a small meter do it yourself, the charging voltage will be up to 5 volts more than the rated battery voltage of the drill, so if you get a high reading don't worry about it. Fast charger will be way over the battery rating, also fast chargers have a cost, they shorten battery life due to heat. I have had many battery powered tools, I have found that the batteries last about 2 years on average. I have this same Dewalt drill driver.
Nov 02, 2011 | Dewalt 7.2-18.0 Volt One Hour Charger
Broken dewalt battery 18v lithium ion 2.0ah flashes fast red when in charger
Oct 07, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Have a Plantronics Cordless phone with the supplied Power Charger (input 110v, output DC9v.500mA.)using in UK with 230v/110v step down transformer, works perfectly. Then, like an idiot decided to use a...
Dec 26, 2009 | Hitachi 12v 3/8" Driver Drill Kit with...
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
18v. charger (dewalt)
I did a little hunting and it seems you really want to use your 110v charger on a 230v supply.....
So you could use a transformer (LINK)
or you could get a local power supply pack.
Read the label on back of power pack that attach's to wall socket and charger base, see what input it can handle, some gear can handle like 110v-230v, others cant ie will read 120v
Any adaptor that puts out the same output as the original would work ie 18v DC 2.5 amps is your specs i beleive so use a transformer or another suitable adaptor
Please check my quoted specs are the same as listed on power pack of your charge ie I am assuming you are using your 110v A.C. to 18v 2.5amp D.C power pack
Jan 30, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Drills Logo
119 people viewed this question
Top Drills Experts
Marvin
Marvin
john h
Are you a Drill Expert? Answer questions, earn points and help others
