Durabrand BH1304D 13" TV Logo
A
Anonymous Posted on Jun 21, 2014
Need code for upc4600b00 with panasonic color tv 01-2006se?
How do I hook up Panasonic DVD player to insignia tv
Match the color coded cables with the same color connectors on the TV.
I have a panasonic CT-3263W and i need the code to program the remote i have is a universal DT008
hola tu el de la panasonic como estan espero ke bien solo keria saver si me puedes aser un favor por que yo tambien tengo una tv panasonic como la ke tu tienes y quisiera saver si me puedes pasar la configuracion de los colores de brillo nitides contraste y eso por que ala mi a le movierron los colores y se mira mui fea la calidad asi que si me puedes desir como van acomodados muchisimas gracias de ante mano saludosss a todos
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
3answers
I am looking for the codes to run my t.v. my t.v. brand is Panasonic and the universal remote I am using is RCA RCU800MS 8-Device Universal Remote. I lost the code book and was wondering if I could get the...
The codes I have are: Code 003 for Panasonic TV
Code 054 for Panasonic TV
Code 055 for Panasonic TV
Code 062 for Panasonic TV
Code 109 for Panasonic TV
Code 130 for Panasonic TV
Code 170 for Panasonic TV
Code 214 for Panasonic TV
Code 350 for Panasonic TV
Code 351 for Panasonic TV
The codes can be looked up here: http://remotefinder.rca.com/default.aspx?site=rca for most RCA remotes. Please note these codes will work for TVs released at least 6 months before the remote was programmed.
I hope this helps.
I have a rca universal remote control and I need a code for a panasonic tv
Code For Model RCR350
Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV
2answers
CANNOT PROGRAM RCA RCR412S REMOTE TO PANASONIC TV.(NOT A NEW TV)
try these
Code For Model RCR412S
you can find codes at http://remotefinder.rca.com/default.aspx?site=rca if you ever need codes for other.
3helpful
2answers
"I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
2answers
Help hooking a dvd player to a tv
  • have you try to hook the rca jacks to the tv they should be color coded red, white, yellow, yellow is the video, red and white is audio. same as hooking to tv box.
2answers
Need to program tv into remote
At universal remote control i.e URC22-9A:
Suitable codes for panasonic TV:
Try 001,003,019,037,040,106,110.111,112,114,190,241
or see booklet of your remote control.
Top Durabrand Televison & Video Experts
matt martin
matt martin
ZJ Limited
ZJ Limited
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
