Do you REALLY need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Computers that request driver downloads are restorable by performing system updates. Once activated, the computer searches to compile the entire resources required from available networks. In situations that computer requests updates least networked would require ascertaining the exact program that is missing feature to cause functionalities. An extensive program malfunction least requires updates however requires reinstallation or new program altogether. The computer displays request to capture drivers as manufacturer designer's notification. Refer with computer support experts since request for missing driver would involve incompatibility condition least updatable. For example, missing computer drivers is installable on devices that are compatible to the system alternately, computers that least allows to replace drivers as incompatible will still request for drivers from peripheral devices. In such a situation, either the device requires attaining functionality on another computer or requires acquiring device that least requires drivers to function. Refer with computer technicians experts to configure the condition.
