Where do I find the model ### on a weed eater featherlite 18cc gas string trimmer ? serial #99111N502460-3 XPWES 0183LT:EM There also is a small tag that has SKU #952711334 FEATHERLITE 24761 01209. Thanks for any help !!
SOURCE: weedeater featherlite seized shaft
If you are talking about your crank shaft being stuck, there is nothing you can do that will work for the long haul. Usually what happens to cause this problem is running straight ( no oil added to fuel) gas to these 2 cylce engines. When you get a "lean seizure', the engine slowly loses power then quits. If you leave it alone for a while, the pull rope will be harder but it will start. The second tome it does this..........well your done. time to buy a new one. Sorry.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
