Question about Canon G12 Digital Camera
My canon powershot g12 lcd works fine but the photos are all 'whited' out
What can i do when my canon powershot g12 pictures are white even though they show up fine in the lcd?
    Master:
  • Canon Master
  • 442 Answers
You may have the exposure compensation settings overexposing you images. Since it compensates without affecting the image prior to shooting, you won't see it until after the image is taken. Check that and the flash exposure compensation too.
Posted on Nov 25, 2014
6ya staff
SOURCE:
Kevin Chong
  • 12 Answers
SOURCE: White photos canon A470? i have a canon
I had this problem too, I think it's the shutter problem, it doesn't close
when a picture is taken, therefore, causing the over exposed photo...I've sent it back to canon, still waiting for the reply...
Kevin - Malaysia
Posted on Dec 10, 2009
pickmynose
  • 161 Answers
SOURCE: Canon Powershot A460 gets overexposed pictures
Change the exposure/ISO through settings.
This is the cause for over exposed images.
Posted on Sep 10, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: A95 LCD/Photo problem
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 31, 2008
old marine
old marine
  • 2277 Answers
SOURCE: How do I take black and white photos using a canon powershot?
Place the camera in P, Tv, Av, M, Movie, or Stitch-assist mode. Press the Func/Set button, and scroll down to the "My Colors" icon on the left side (second or third icon down, should show "My Colors Off" at the bottom of the LCD). Now use the left/right buttons to select "B/W", and press the Func/Set button again.
Posted on Mar 16, 2010
Rammsteins
Toms Safranovs
  • 300 Answers
SOURCE: canon powershot A470 problem when
The shutter flex cable inside the lens is broken. Happens to all cameras from Canon A4xx series. At day the images will be overexposed with horizontal lines on it, but it could look better at dark / night. The FLEX has to be replaced. Canon doesn't supply new flex cables for these, but there are some cheap copies on ebay. But as these brake very often, I wouldn't suggest you investing money in this camera, because it will brake again sooner or later.
Posted on Jan 26, 2011
Canon powershot G12 takes pictures but the LCD screen isn't showing anything
Is it only the pictures? What about other normal video function? If you don't see anything at all, the LCD is damaged (dry). You could have it replaced at a service center but check out the cost first.
Jul 29, 2015 | Canon Powershot G12 10 Megapixel-5x...
We have a Canon Powershot G12 camera. When taking a picture a red flashing camera appears at the lower left side of screen, the picture comes out white. What do we need to do?
That is the camera shake icon. When you press the shutter button halfway in low light conditions where camera shake is likely, a flashing (g0035839.gif) will appear. You need to change your settings to compensate, usually setting the camera on P or Auto will usually get you an acceptable image. Check the user manual or download it from the Canon website.
http://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDMwMDAwNDE5MTAx&cmp=ABR&lang=EN
Oct 09, 2014 | Canon Powershot G12 10mp 5x Digital Camera...
Why won't the screen on my Canon G12 display an image so I can take a photo??
The Display button toggles the information shown on the LCD (or turns it off entirely). Make sure you haven't inadvertently pressed it and turned off the display. It works as follows:
  • Press once for Normal view in LCD viewfinder
  • Press twice to turn on Rule of Thirds grid lines
  • Press three times to turn off LCD display
  • Press and hold 1 sec. to decrease/increase LCD brightness
Aug 02, 2014 | Canon Powershot G12 10 Megapixel Digital...
Hi! The screen of my canon powershot G12 is black, even when I take a picture, the picture is black. But I can see previous pictures. What should I do?
Get it serviced by a professional shop. It's probably the CCD that is giving you a problem, those are the classic symptoms of that sensor failing. If you need help with it, try this site: www.camerasandparts.com They are the place for help with the Canon Powershots. That's all they specialize in, they do excellent work and they're about have of what Canon wants to repair these cameras. They're the place for help with a Powershot. Best of luck with it.
Sep 07, 2011 | Canon G12 Digital Camera
When i take picture,the picture is white n some time become very very bright, but if take video is ok.
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
May 04, 2011 | Canon PowerShot A460 Digital Camera
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear..
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
The picture we have taken was white/grayish screen- no images..
I got it repaired at canon service center in India for Rs 1900.
Next camera I will insure !
Jan 19, 2009 | Canon PowerShot A460 Digital Camera
Regardless of setting, picture is extremly over-exposed
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Although it's not showing on the LCD, recommend contacting Canon anyways (it can't hurt). Please check the following two links for more info:
Mar 16, 2008 | Canon PowerShot A80 Digital Camera
Taking photos
I have the same problem too with my a430, when i shoot outdoor, it's like over exposed, more of a white, but it's good indoor shooting aside for some horizontal lines. i already reset all the settings, still nothing changed
Mar 03, 2008 | Canon PowerShot A430 Digital Camera
Canon G12 Digital Camera Logo
227 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
