What model is the hvac unit that it is hooked to? There is a high possibility that the wires are not hooked up right. You should check the connections at the hvac and see if they are color coded and wired right.
Testimonial: "This just started happening so it can't be the wiring."
Hello friend, thanks for the post!
From my understanding your Frigidaire air conditioner is rapidly turning on and off, this could be due to restricted air flow. First, I would check to make sure the air filter is clean because a restricted air filter could cause this problem. Secondly, check to make sure nothing is blocking the air flow like drapes, blinds, or furniture. Lastly, your condenser coil could be dirty or blocked I would make sure if it installed in the window that no bushes or trees are blocking the coil. I hope this helps. -Matt
