Snagging
First thing to check is the drum alignment to be sure that it has not shifted from wear. Open the door and reach in and see if you can move the drum up and down or side to side (not spinning) but pressing on it. IF you can then it needs to have some guides replaced. However if it is tight then you need to get a drier sheet or something similar and run it along every inch of that tub and the paddles and the back to see if it snags on something.
Thank you for your post, friend!
From what you are describing it sounds like the felt may have come off your Frigidaire dryer. I would recommend seeking assistance from a professional to come out and properly repair your appliance. This would help avoid any unnecessary part purchases. -Matt
