What causes the Hoveround Mpv5 to beep all the time? It runs, but some times it start beeping for WHAT REASON?
SOURCE: How can I get a manual for the Hoverround MPV5?
If the power chair was stored for a while, the batteries may have gone bad. There is a gel inside them that needs to be put on a current regularly or it will solidify. When you connect the charger, you get a green light because it senses the batteries are full; unfortunately they are full of crud, not power. Try replacing the batteries to see if that solves the issue. You can probably take them to an auto parts store or Interstate Batteries to have them volt tested. The type of battery you need is a U1, 12volt, 33amp and you will need 2 of them.
