Good Afternoon Friend,
I understand that your Frigidaire dehumidifier, model# FAD504DUD, is freezing up. First, if your dehumidifier has been turned on recently, this is normal due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Secondly, make sure the room temperature is above 41 degrees Fahrenheit. If it is too cold in the room, the coils can freeze. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
I have the same issue except the complete unit is freezing up and stays frozen.
