SOURCE: cannot connect to online projects in american
You have to make sure that you allow your program to access the internet. By default, the firewall is set to block all of your programs. To make an exception:
Click the Start button, go to Control Panel, click Security, and then click the Windows Firewall.
In the left pane, click "allow a program through Windows Firewall."
You have to have an adminstrator account, and you may be prompted for the password at this point.
Check box next to the American Greetings, and then click OK.
The other problem you can run into is with active x controls. Allow programs you trust to run this code, or you will not have full use.
I hope this helped. If you have time, please let me know if this addressed your problem by rating the solution before you go. Thanks for using fixya!
SOURCE: My Creatacard Gold does not work with Windows 7
my creatacard gold c.d dose not work on my new laptop which is window 7 can you help
SOURCE: I have the creatacard gold
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility".
This will allow you to choose on what type operating system your program
will run. Just reply back if it still doesn't work.:D rate and vote
for me:))
SOURCE: I had Creatacard Platinum 8
You can download Creatacard Platinum 8 from the below link;
http://conysoft.com/c2z/downl/american%2Bgreetings%2Bcreatacard%2Bplatinum%2B8.html
This will most likely work on windows 7. But if it doesn't work, then it means you will need to get a new disc compatible with windows 7.
Make sure it is printed on the disc cover that it is compatible with windows 7 before purchasing it. Or confirm from the seller before purchasing.
Good luck.
