Microsoft Internet Explorer 8 Logo
A
Anonymous Posted on Jun 20, 2014
How to getrid of administrayor message cant access program must be administrator and how do i log in as administrator
Have tried everything am a seniour user how do i log in to be an administratoe also phoned provider no hep at all lap top was a reconditioned gov one work ventures is installed but cant find the help stuff thanks gail
jeya singh
Level 2:
  • Expert 79 Answers
  • Posted on Jun 20, 2014
jeya singh
Expert
Level 2:
Answers
79
Questions
0
Helped
26361
Points
186
To enable the built-in Administrator's account by using the Command Prompt please follow these steps:
1. First you'll need to open a command prompt in administrator mode by right-clicking and choosing "Run as administrator"
2. After that you only need to enter the simple command below to activate it.
net user administrator /active:yes
3. After that you enter following command
net user administrator 123
where 123 is pwd for administrator
4. Now log off you can see administrator account
Access programs Fincon Trial software problem
Make sure you are logged in on an administrator account
If I have an admin account on my home network, why do I keep getting the message that an Admin account is required to run Linksys advisor?
Depending on the User Account control , You may be logged in as an administrator but not allowing administrative access to the program. Usually Right clicking on the application could reslut in a RUN AS administrator...That should allow you to run the advisor. By default Administrator or not, is you try and run something that requires an administrator access ( registry changes.eg ) It will deny this default..
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
I'm having problems connecting. I ran the initial CD setup and everything seemed to run fine but when I try to access the 10.0.0.253 I receive an error message. The camera is set to wired and is...
"I receive an error message" (sic) What is it exactly, what happens? Also Install everything as Administrator, ALSO set the setup/install program's .exe in, Compatibility Mode for XP SP2. and Run the actual program's .exe as Administrator, too. Ensure all network settings are correct too.
3answers
What to do Microsoft XP Service Pack 3 Error Message Access Denied. Step by step please I,m not to techie inclined.I tried to download after disabling anti virus as Microsoft suggested but still access...
Hello and thank you for using Fixya services.
From the sounds of your issue, it may be that you have malware or a trojan. You can run a scan using this free malware/antivirus protection. I am not sure which antivirus you are currently using but this one is free and has excellent reviews. You will need to uninstall your current antivirus protection first before installing this one.
Malware/trojans can disable your antivirus programs and make it look like everything is running smoothly. This would also block Windows updates. By running a thourall scan with another program, you can get the malware out. Even the best antivirus can be disabled.
Please let me know i I can be of further assistance
1helpful
The initial installation was sucessfull. but after several days I needed to access the e-manual I encountered the following problems. The same e-manual appeared but with a slight difference I could...
If you go into control panel>user accounts, you can then change accounts, or delete any alternate profiles you may have. If you are not logging on as the system administrator, you will run into a host of problems in trying to configure your computer and accessing certain programs.
If you have setup a password during install, you must log on under the administrator profile and enter the password. If you are the only one who uses your computer, you may consider that you do not need alternate profiles at all.
If you need additional information or help, please write back.
Thanks for using Fixya.
Alohabob says i need to 'make sure i'm logged in as administrator
I truly have no idea what is that, or how you make it work, but usually when a program needs to be run with administrator rights, I just right click and choose run as administrator.
Some of the sites are banned in my computer
"your administrator didnt do this guess who did this"
if that is the message you are getting ... it sounds like someone has set the parental controls to prevent those sites from being accessed.
Cant uninstall program
Are you using Vista or Xp?
If you are using xp the solution is quite simple.
Restart your computer and when the bootup shows up press F8. Now you should get a list of options including safe mode. Select safe mode. Now when xp shows up Administrator will be a profile. Enter your administrative password and log in. Now remove the program. Then try changing your main account to a standard user and then back to an administrator.
If you are using vista i found this was a bit more difficult, for i encountered the same problem. I created a new account and called it "Amin". Make the new account an administrator. Then log in with the new account and remove the problem. Vista has too many bugs in my opinion.
Hope i could help.
2answers
Cannot access my control panel
you should be able to open another account in the users, to do this start the pc in safe mode F8 while booting,when in windows either open a new account or change your old one to administrator.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
