Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
When I put burner on it says o n for a bit and shuts of and power off indication comes on
Stove power goes off
Kenmore range indicator light for element does not shut off
Tempature probe(Temp sensor) on that burner is malfuncting . Replace that probe.
www.searspartsdirect.com/partsdirect/brands/kenmore-parts
Jun 30, 2014 | Kenmore White Electric Stove
How do I plug back in the GE stove top burners after unplugging them?
The two leads from the burner fit into a socket in the stove top. It's a bit tricky to get it in just right. If the three metal "legs" on the burner fit snugly into the three slots on the stovetop you did it right.
Aug 26, 2012 | General Electric Ge Stove / Oven / Range...
After using the stove top and all the valves are shut, the igniter continues to click. Not sure which particular one, but I presume the right front, which is the most common used on the stove and the last...
One of the switches that turn on the spark when the burner is turned on has became stuck so even when the burner is turned off it still thinks its turned on. It very well could be the one for teh right front burner or any of the other 3 switches.
Depending on your mechanical ability its not too hard to figure out which one it is. What ya need to do is remove the panel over the burner valves so ya can get to the switches which slip over the stem of the burner valves and remove them in the off position and use a meter set to measure continuity and check each of the 4 switches when in the off position and see which one has a circuit (continuity) when off..when you figure which one has continuity when off that will be the one that is causing the stove to spark when off. Be sure to check all 4 since more than 1 could be bad.
BEFORE ATTEMPTING TO DO THAT AND CHECK WHICH SWITCH IS BAD BE SURE TO DISCONNECT THE POWER TO THE STOVE
GENE
Sep 16, 2011 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Water boiled over on the Right rear induction side. Stove shut off. Now the Right rear burner doesn't work and flashes and "F" when I set any temperature. Stove thinks I have the wrong type of...
Generally there is a number after the F. It sounds like some liquid got into the electrical, sometimes if you wait about a week for it to dry it will work. If not, you would need to call a service tech
always unplug electricity before attempting to repair on any electrical appliance
Sep 14, 2017 | Electrolux 30" Built-In Electric Cooktop -...
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Heat shuts off after about 3 seconds, recycles
its not suppose to stay on for long time...its suppose to recycle...set it at high heat all burners should come on for few seconds and then go off for few seconds...small burner do faster then bigg ones
Nov 10, 2009 | Jenn-Air JED8430 Electric Cooktop
Ignition will not stop clicking...
Did you clean your stove recently? If the switches under the burner knobs get wet they will cause the burners to click. Unplug the unit or shut off the power for a day. Once the swithes dry, it should work normal.
May 05, 2009 | GE 30 in. Profile JGP932 Gas Cooktop
Jenn-Air electric stove top - burners/fan won't come on
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
Top Jenn-Air Cooktops Experts
Marvin
Marvin
MARLON KELLER
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
