Sorry to hear you're having difficulties with your DC27. If the wand seems to be jammed, you should be able to free it by following these steps:
- Pull up wand as far as it will go
- With the rear of the cleaner facing you, follow the hose down to where it attaches at the base of the cleaner
- Holding the loose section of hose to the side, pull the hose release tab to detach the end of the hose from the cleaner
- Allow any twists in the hose to straighten themselves out, and check for any blockages in the hose which may be preventing the wand from extending
You should now be able to pull the wand out to it's fullest extent, allowing it to detach from the cleaner. Once you've reattached the hose to the base of the cleaner, you should find the problem is resolved and the wand and hose can be used as normal.
If you've tried this and are still concerned, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
