Whirlpool AD50USS Dehumidifier Logo
A
Anonymous Posted on Jun 19, 2014
Manuel for K-QD0P
How do you set the dehumidifier
How do I get a user Manuel got Ebac880 dehumidifier
http://www.produktinfo.conrad.com/datenblaetter/525000-549999/531001-an-01-en-Luftentfeuchter_Modell_660.pdf
1helpful
I dont know how to work my dehumidifier its haier hdn455 i dont know where the manuel is
Lament no longer. The link below is to your Owner's Manual. You can download and print it for future reference.
http://www.managemylife.com/mmh/owner_manuals/19991/HAIER-Dehumidifier-L0522296
Hope this helps to you get it up and running.
Can I get a manuel for this?
Yes , go online to the Haier web site, you will need the model number and the serial number to get the right manuel.
I lost my manuel for Maytag dehumidifier model M7DH65B2A. May I download a manuel for my dehumidifier?
Hi! Your dehumidifier was made by Fedders for Maytag. However, Fedders as it used to be, not longer exist. It is now Airwell-Fedders. And they don't provide a download feature. However, you can call their Customer Service Dept 866-829-2440, and they may be able to email you a manual for your model. Be sure to have your correct model number handy, when you call.
Hope this helped you. Please let me know. Thanks.
2helpful
Lost instruction manuel
Check this link to download the DeLonghi Dehumidifier Instruction Manual for DeLonghi de 400 Dehumidifier (PDF format)
Hope this helps (remember to rate and comment this answer).
Won't shut off when setpoint reached / full switch works
Your unit may be designed to run the fan continuously despite the fact that the room has reached the set humidity level. This design feature is intended to keep the air moving which helps mildew problems in both the room and on the surfaces of the dehumidifier itself. Check your manuel.
No manuel, do not know how to work
Hi Journeay,
The dehumidifier is telling you the humidity in your house is 45-50 % so it will not run until the dehum thinks it is over 60%. When you set a humidity it will show the setting then it will tell you the humidity in the house. Sometimes they are wrong, and somtimes the humidistat goes bad. I would suggest setting the dehumidifier lower than the 45-50 and see if it comes on. This time of year the humidity is usually low depending on your location. I have already put mine away for the winter. Please let me know if you have any other questions and I really hope this will fixYa. If not just let me know.
Mike
8helpful
2answers
We lost the directions for our Danby dehumidifier. The model number is DDR557HE. Serial. No. 0107050701350. Can you help me out. T. MacKay
I had the same problem but was able to find a link from "Danby's" website. Hope it helps!!
http://www.danby.ca/cms/uploads/products/en_manual/DDR557HE.PDF
Top Whirlpool Dehumidifiers Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
