Epic View 550 Treadmill Logo
A
Anonymous Posted on Jun 19, 2014
Making a tapping noise - Epic View 550 Treadmill
2answers
I have a 2002 ford f150 supercrewcab 4door 4.6 ltr. that has what sounds like lifters tapping, I took a piece of garden hose and listened to different parts of the motor trying to locate the tapping noise,...
Injectors do make quite a racket but mostly they are so well insulated they can't be heard inside the car and in the engine compartment the noise just becomes part of the general engine noise.
I have noticed a few cars where the use of semi-rigid (nylon) fuel supply and return pipes transmit the noise to the bulkhead/firewall which magnifies the sound.
I have a 2004 ford f150 making a tapping noies can it be the cam phasers going bad
check oil level ---yes it can but tapping noise can be a lot more reasons --worn oil -low oil pressure--low oil level--rocker loose-worn or damaged lifter-worn damaged valves --timing chain --water pump--pulley --really anything can cause a tapping noise --try to isolate the area or sound and diagnose problem
Tapping noise in engine
What's That Ticking Sound Coming From Your Car's Engine?
www.popularmechanics.com/.../whats-that-ticking-sound-coming-from-...
Apr 18, 2014 - My engine has developed a strange ticking sound. Its whisper-quiet before an oil change, and then makes a loud tapping after a new filter and ...
Engine Tapping - Auto Repair Help
www.auto-repair-help.com/auto_diagnostics/engine_tapping.php
ENGINE MAKES TAPPING NOISE WHEN STARTED by Mark Davidson. SYMPTOM SUMMARY The engine emits a tapping noise on start up. The noise may ...
Engine Ticking Clunking Noise - Repair - YouTube
? 9:37
https://www.youtube.com/watch?v=ilDtnJi_BS0
Mar 15, 2013 - Uploaded by knurlgnar24
One of my vehicles started making a rather disturbing sound so I went to investigate and to hopefully fix it.
Tap tap tap noise when the belt turns on. consistent.
can you determine where the noise is coming from . under the front hood or back. if you can remove the hood and look at the drive belt for fraying . also look at walking belt for fraying. any loose piece will hit something and make noise with every revolution
Tapping noise - oil pump?
Its possible the oil pump is going bad, but I doubt it would make the noise you describe.
Usually a tapping noise is a valve lifter or a piston connecting rod.
And low oil pressure could cause either, as well as dirt blocking one of the oil passages in the engine block.
American Standard bathtub tap noise
possible that the pipe's are not,secured properly in wall. and you did not say what kind of faucet you have, but if it has washer's,the screw's that hold them, may be loose.
Feb 19, 2010 • Home
1helpful
Loud tapping noise from 2005 grand prix 3800 engine
It could be you are low on oil;using the wrong oil;a possible loose connecting rod,or,maybe a bad or stuck lifter.
Neil
2answers
2001 Chevy Metro
Check Utube for lifter tap, valve tap, and rod bearing noise. If you pull each spark plug one at a time, plugging it back in after each one, the tapping will go away if it's a rod bearing. At any rate, on your next oil change add some valve-medic or similar additive for valve noise. Make sure you follow direction or you will get massive lifter tap if you pour it into a cold engine.
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
